How good was the drag comp!!! The Skylines beat everything until the last race where the torana had roughly a 3/4 car langth head start at the roll start - the gtr was catching the torana by quite a bit by the finish line
Hehe, yeah, was in the pits, they were trying to convince the officials to let them do a rerun, but by the time they finished the track was already cleaned up and ready for the next event :O that skyline was a machine :P
Yeah damn good job Buster..
and man.. those autostyle machines were killin it..
if they had done standing starts I think the result would have been a little different..
great day.. and DAMN i'm sunburnt..
drift was alright.. bit boring, goto say, for $35 the day is really unorganised..
Yeah the GTR's would've been good from a standing start
Was there a reason that didnt happen? e.g. the officials didnt want nissans winning?
The marshals were too slow. like the green alien that fell out on the track
1. why was it allowed in the car unsecured? from the anouncers comments it wasnt the first one to fall out onto the track
2. Why did it take the announcer asking for a guy to clean it up AFTER THE 2 GTR'S HAD RAN PAST IT to get it picked up?
Also the waiting time was nothing short of ridiculous
Yeah.. ^^ that was crap.. they go on about track safety.. yet when something falls on it.. they just leave it there..
Mate and I were standing going.. ok.. so.. someone will go get it now.. before.. oooohh.. noo.. too late.. they'll just run the GT-R's anyways..
edit: me just grumbling.. probably due to the sunburn..
JEV-666 did alright too in the R33 GT-R.. how'd you go with traction out there buster??
Edited by Links
guys its called street racing, which at the end of the day is a way around the agreement between eastern creek and wsid that eastern creek wouldn't have drag racing at there complex
it has nothing to do with nissans
whens the next kind of event like that.. wouldn't mind going..
also - who was the photographer you were talking with out there.. wondering if he's got a website?.. wouldn't mind seeing some of the photos..
Just found your photos Oricle.. llooking good..
Edited by Links
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
