Hey... a cruise is being organised for the south coast of NSW Areas included are from Nowra to Eden , will be meeting up in moryua heads.
All you guys in the ACT are more than welcome to come aswell :D
Heres a rough timetable for us along the coast -
MEETING POINT TIME
Nowra maccas ( not bomaderry ) 9:45 - 10:00
Ulladulla?? (not sure yet ) 11:15 - 11:30
Bega skate ramp 10:30 -10:45
Narooma light house 11:45 - 12:00
Batemans Bay Bowling club carpark 12:00 - 12:10
Moruya swimming pool carpark 12:30
Destination 12:45(ish)
Feedback is welcome :mad:
https://www.sau.com.au/forums/topic/108148-south-coast-cruise/
  • Replies 104
race_snooze - We are aiming for everyone to meet up at Moryua swimming pool carpark at 12:30pm and as soon as
all partys arrive then we'll head over to the Destination/BBQ area at around 12:45 ish :(
Stevie - I understand your concerns. The calender and footy timetables are your friend.
We hope you can make it :(
chintami - sweet! please let KANO know that ur coming.
Call or msg him on 0421278639 :(
We hope you can make it :P
Yeah the only problem with football is that you are given no more than a couple of weeks notice as to when you play. The draw simply says I have a game that weekend. I wont know what day its on until closer to the event.
Heres a rough timetable for along the coast -
MEETING POINT TIME
Do you guys want to arrange a place to meet so you can cruise together?
Any feedback welcome :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
