Dude it is damn hard to do it with the hand controler the best bet is to brrow or buy the GT3 wheel and pedels. Then yor just get a S15, RX8 or Nissan Z car do everything bar full LSD custimization just put the 2 way lsd on and then put supper softs on the front and simulation tires on the back. Then its just a case of agresive turn in and the ballence the over steer with the wheel and gas.
https://www.sau.com.au/forums/topic/10830-virtual-drift/#findComment-208597
I found the 200sx(S14) to be the best drifter.
ADZ has described the best setup though I always go for the normal tyres.
What is your favourite drift track?
I like the complex string or apricot hill, but I used to like highspeed drift on redrock in GT2.
Hooks
https://www.sau.com.au/forums/topic/10830-virtual-drift/#findComment-246115
now, i been playing with gt3 and drift a bit lately
and are you guys talking fish tailing ?
Or in corner dirft ?
Or before corner drift ?
The s13 drifts hard and complex string is good but the damn straight drive me nuts, with top speed of 180 lol.
Yer apricot hill is up there as top track.
https://www.sau.com.au/forums/topic/10830-virtual-drift/#findComment-263715
I can drift in gt3 like you wouldnt believe, if anyone is serious, send me an email and i will give you setup info for most the nissans, well all the good drift cars....i just wish i could video tape my gt3 drifting to post, you wouldnt belive the shit that can be done in that game, constant drift on almost everytrack, soo smooth, so sideways, so controlled.....as stupid as it may sound, mastering drifting on GT3 as helped me drift in real life, there are alot of basic drift tech in the game you can use in real life.
https://www.sau.com.au/forums/topic/10830-virtual-drift/#findComment-280760
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
