Just wondering who would be the best company to go with for my Toyota Supra 1994 RZ
Running a bit low on cash after just buying the car so I cant pay the full 12 month cost of Just Car Insurance and would prefer something by the month.. any help would be appreciated.. thank you.
I am in postcode 5114
Rating 4 Driver
18 years old
TRy H2O ask the RAA insurance for the number $1250 classic or just car $850 with them {h20] :no:
any of you guys consider that you might hit a porsche and end up paying for it for the rest of your lives . :no:
I would consider you STUPID not to get comprehensive insurance .
If you cant afford the insurance how do you think your going to pay for the running costs of skylines!
secondly get a non turbo version and wait till your over 25 before you get a turbo version then the insurance might be more affordable.
cant have your cake and eat it all the time .
Sorry this might not be what you want to hear but crashes do happen.especially when you dont expect or wish them to happen.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
