If you want free tickets to the motor show send an Email titled: BBCB (Best Car Buys) to - [email protected] - with your name and contact details. Hurry limited amount of tickets first in, best dressed.
Did somone say, Free? I'M THERE! :) Email sent! :banana:
It wasn't full of crap.. there where 100 tickets available
I sent a email at 8:07 this morning .. and recieved a confimation email back at 9:02 to say that my ticket can be collected from the door (with photo ID)
So I guess I'll be going :D
Yeah I got a responce too:
-----Original Message-----
From: *********@*********gm.com [mailto:*********@*********gm.com ]
Sent: Tuesday, March 07, 2006 11:20 AM
To: [email protected]
Subject: BBCB Free ticket to 2006 Brisbane Motor Show
Congratulations!
You are one of the first 100 people to respond to the BBCB Motor Show Ticket giveaway!
Collect your FREE Motor Show entry ticket from the information desk located in the main foyer of the Brisbane Convention and Exhibition Centre.
Tickets can be collected during show opening hours until Sunday 12th March
- please note ID will be required for tickets to be issued.
Enjoy the show!
Show Opening Hours
Weekdays: 12pm - 10pm
Saturdays: 10am - 10pm
Sundays: 10am - 6pm
Venue location
Brisbane Convention and Exhibition Centre Cnr Merivale and Glenelg Streets South Bank Brisbane QLD 4101
GM Holden Ltd may use the details you've provided for future marketing activities. If you do not wish to recieve any further correspondence from Holden, please respond by return email advising that you do not wish to recieve any further information from us.
Not bad considering:
You can pre-purchase your tickets and redeem them on any day of the Motor Show between Friday 3 – Sunday 12 March.
Prices:
Adults: $16.00
Child: $10.00
(5 - 16 years of age, children under 5 are free)
Family: $42.00
(2 adults, + up to 3 children 5 - 16 years of age)
Concession: $13.00
(Government issued Aged Pension, Senior and Disability card or Full Time Student card must be produced on request at entry)
* All prices are inclusive of GST.
Looks like it is legit, the email that I got originated from a mail server in Detroit, from the GM HQ IP range, so I would say it is legit.
I'll be taking print outs of the email, and if it doesnt eventuate well then South Bank is just a short stroll away :D
Big thanks to 34-JET for the heads up, you're a champ!
Woohoooo! I got in too! I only hope its not a hoax, might be good if we printed that reply email to bring with us. Cheers for the headsup!
BAM,
I cheated, if you look at the reply email it is sent to a certain person @bcec.com.au.
So I called up the Convention Centre on 3308 3000, and asked to be put through to that person's name and spoke with her, and she said that no, it was legit and she has been printing them out and sending them hourly down to the information desk. The ticket is for 1 entry for that day only, I must say she was very helpful and friendly. She aslo mentioned that Holden were sending through the same emails to her as we recieved, and in no way keeping record of how many had been given away, but was adament that Holden was only giving away 100.
So that is good enough for me!
I just came back from the motorshow and yeppp u bet it was free :D For those who are going, make sure you make ur way to the information counter at far end of the auditorium to collect your tickets...don't go to the ticket sales booths. Thanks again 34-JET! champ!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
