hey ppl i've see a few cars getting around now with what appers to be some sort of mirror tinting on the bottom 1/3- nearly half way up the rear windscreen, changing to darkest legal tint on a good half of the top rear windscreen,
its not completly mirror tinting as you can see through it if you look hard enough
justy wondering if anyone knows if this is legal/ and insurance friendly
cheers
https://www.sau.com.au/forums/topic/108761-12-mirror-tint-on-rear-windscreen/
cheers
You're talking about 'Fader tint' I think (bottom half chrome/mirror, top half Black, blue etc). It ain't legal either... mirror is 5%, black part is 20%. Legal is 35% light transmission.
Is it definate that you cant have dark tinting on the rear screen?
I ask as a lot of vans have there windows totally black and some even replaced with steel in the case of refridgerated ones. And trucks cant see a damn thing at all besides a huge box.
Or is it just a commercial vehicle thing?
pretty sure that vans have different rules, they can paint their windows etc.
spoke to my tinter, who did my car ion 5% all round, thats the only reason he can get that tint, and he cant get large amounts cos the sales of 5% were monitored..
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
