Andrew,
My oldies run a 2500+ barton thats been running @ 3200+ speeds for the last couple of years.
As the multipliers are locked on the bartons all you can do is fiddle with the fsb. Depending on your m/board and ram you should be able to simply jump the fsb up to 200mhz and push the chip to 1.8v and it will be stable.
The old amd's do pretty damn well, just need to get their core speeds up to 2200mhz (~3200mhz p4 speeds). Mines running at 2300mhz @ 1.9v.
yeah unfortunately my machine hangs if I go over 180DDR fsb .... how do you change the chip voltage? I don't want to blow up my PC :O .... I do have one of the best air/fan coolers around, so heat isn't a problem.
Andrew,
What m/board are you running?
The cpu voltage is in the bios. I wouldn't go pushing it past 1.8-1.9v as heat does become an issue, even with a top end air cooler.
You may also need to bump up the vdd (chipset voltage) to 1.7.
If its nforce2 it will automatically flick over to the 6th divider when you select 200fsb so there's no worries killing pci cards and what not.
I run one of these suckers with a thermal take smart fan II, i've attached the temp sensor on to the core via thermal epoxy, it works well, idling around web browsing nice and quiet, in games etc it ramps up. The fan pushes around 75cfm at full noise 4800rpm.. The HSF cost me ~$80 some time ago.
Before that I was running an old SLK-800 that I passed on to my parents machine.
that is one funky looking heatsink Joel!
I have an Epox 8RDA+ - yeah I am sure it had voltage adjustments in the bios now I think of it.
I have a Thermaltake Silentboost K8 headsink and fan, which keeps my CPU at around 45 degrees even under load!
Yeah I might play more with overclocking at some stage- probably when I am closer to upgrading. I had a bad experience with my old FX5600 video card - fried it when bumping the fsb up :O
The 8RDA+ will push 200fsb no problems, I suspect the stability problem you have encounted are due to the lack of cpu and possibly chipset voltage.
The 8RDA+ runs an AGP lock you won't have problems frying vid cards should you push the bus speeds too high.
The nforce2 boards don't run a pci lock but they do run dividers.
The boards dividers are setup as the following to achieve the 33mhz pci speeds.
133mhz FSB (266DDR) / 4 = 33mhz PCI
166mhz FSB (333DDR) / 5 = 33mhz PCI
200mhz FSB (400DDR) / 6 = 33mhz PCI
So anywhere inbetween those fsb speeds you are using the divider prior.
As you are running a 180mhz FSB (360DDR) the motherboard will be running the divisor of 5. So your PCI bus speeds will be slightly out of spec at 36mhz. 36mhz is no problems, I've only seen problems when pushing 42mhz but it really does depend on the card.
42mhz is impossible on our nforce2 boards UNLESS we run a FSB of 252mhz or 504mhz. 'Some' have had their nforce2 boards running such a speed but you will notice they tend not to run any pci cards and disable onboard sata/lan etc.
The most I've pushed is around 230mhz and that was after a VERY nervous VDD mod.
So either way with the Nforce2 board you won't be frying cards unless you manually jump in to the bios and ramp up the agp speed from 66mhz.
The nforce2 boards really are pretty easy and safe to overclock.
What board did you fry the FX5600 with? I'm assuming a via based board as its impossible with the nforce1/2 board unless you accidently bumped up the agp frequency. :O
thx for the info mate.
The video card I fried I was trying to ramp up the actual GPU speed of the AGP card - it was running 350Mhz, and I was told you could ramp them up to 400Mhz .... turns out they were wrong. I was ready to upgrade to my 6600GT anyhow - that's why I messed with it.
Yes vid card overclocking is nervous territory for myself..
I've pushed my 9700pro quite hard in the past with a huge old cpu hsf hanging off it but it is iffy, on a couple of occasions i've had it display garble so its running @ stock speeds.
The increase in gfx performance when overclocking the vid card is minimal and almost not noticable in games. In my experience anyway.
I had a good game of Hitman blood money.. I gave up after snipering 2 dudes and couldn't find the third.
Runs well though.
well, I am now running as a 3200+ (2205Mhz) and seems 100% stable. All I did was bump the fsb up to 200DDR, and upped the CPU voltage to 1.8v. Unfortunately I have no vdd adjustment in the bios, so thought I'd try CPU on its own. Seems to work. Thanks for giving me the courage :O
I was tempted to adjust the AGP voltage but chickened out.
Screenie attached of my new pi calcualtions - only knocked 3 seconds off, but better than nothing!
lol...
Don't touch the agp voltage. bzzzzzzzzt :O
Only bits safeish to touch are the cpu (max 1.8-1.9), vdd (max 1.8, 1.9 with better cooling), and mem (max 2.9v).
Fingers crossed the std vdd works ok at 200fsb. :O
To improve superpi a little more the only way is to tighten up the ram and possibly push to 2300mhz. Which I think is out of the question, 2200mhz is all your going to get with a vdd ~1.6v. My board needs a vdd of 1.7v+ @200+mhz.
I must also add..
lmao at the deleted posts doc on the desktop of the screenie. :(
LOL too
hey andrew thought u said sum1 was banned @ the cruise the other day i saw them posting :S
the third dude to snipe is standing on 1 of the ferris wheel carages
Edited by Madaz
yes lol .... he is a bloody nuisance. I have kep a word doc of all his deleted posts for posterity.
yeah I did suspend his account for 365 days - well I thought .... not sure what happened. Maybe he is supposed to get a 3rd chance, so will let him be until he disrupts the peace again, then come down on him like a ton of bricks. If he behaves, then everybody wins.
I will d/l and have a look at the new Hitman .... sounds good!
I have been playing "The Elder Scrolls IV - Oblivion" for the past 4 hours - boy it is an addictive game!
How right you are! I have been addicted to this game for a month. There is just so much you can do and the world it increadible!!
A mate of mine plays World of Warcraft, says its more addictive then crack....im not going to touch it! :
good thinking 99
WOW is weird, a mate down the road has it and LOVES it and says to me u MUST get it i went and watched him play it and didnt think much of it
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
