R factor is free to Down LOad you have to pay for it when you register, I have broad band but my Ozemail account its really slow 3kb's and i only have a 300mb DL limit:(
i'm just after the setup and installation files
M8 you didn't have to DL it i was after someone that already had it
Edited by Whiplash
well as i said the download is 688mb i have it now but dont u live down south
**EDIT**
ive used 58% of my monthly quota and im not about to use 4gb in 4 days since it a legitamate download i got no problem helping cept for the fact i dont have anything but DVD's to burn it on where about you work and maybee we can arrange sumthing
Edited by Madaz
Guys im noticings you are all pretty cluey i need some tech support i recently had this cpu in my MSI K8T Neo-FSR Motherboard ----- Athlon 64 3000+ 2000 MHz 512 KiB 800 MHz 10x 1.50 V 89 W Socket 754 ADA3000AEP4AX until i broke of one of the pins on a fan clean (bad story).
I got another cpu which i thought was just a desktop one but after changing power supplies and ram i noticed it was a Mobile one. Is this CPU my Problem??????? ------ Mobile Athlon 64 2800+ 1800 MHz 512 KB 800 MHz 9x 1.35 V Socket 754 AMD2800BKX4LB
DRIVING ME CRAZY
ps ( my comp problems were automatic reboot, memory dump, irq issues, stalling in bios setup)
Hope someone can help
Erin
what type of ram are you running it may even be driver issues
sum AMD chips require extra drivers
AMD Athlon™ 64/FX Processor Driver for Windows XP
if thast isnt needed im sure someone will say
More stuff to monitor your chip here the last few look ok like AMD Athlon™ 64 Processor Cool'n'Quiet Software
http://www.amd.com/us-en/Processors/Techni...71_9706,00.html
maybee your PSU is fluctuating in its volts and when it does your cou reboots
Edited by Madaz
I doubt the Mobile chip will be the cause unless its faulty.
I'm not sure how it is with the A64 Mobile chips but previously mobile chips are nothing more than a high grade desktop chip that is able to run high frequency's at low volts. So the item of choice for overclockers.
Have you tried the usual bios update, rip one stick of ram out, memtest etc?
lowered my 7950GX2 price to 650 dollars now. its brand new. thats a 110 dollar drop. details found in the For Sale section in the forums. RRP still around 1000 dollars and this ones new (4 weeks now) and never been OCd.
http://www.skylinesaustralia.com/forums/in...howtopic=143697
In regards to your problem. Can you state here what:
Motherboard
RAM
CPU
PSU
3d CARD
Hard drve
And then we will be able to have a slight clue as to what may be happening.
Edited by SAZilla
Skippy, I have a XP 3200+ you can have for $50 if it will get you out of a spot. Obviously no charge if it doesn't fix your issues - yes try before you buy. Comes with stock heatsink and fan, but will need new thermal paste. Let me know.
try doing this, if you have dual channel set up, take out a stick of ram, then if u installed the CPU yourself, make sure the fan is on correctly, might even be a heat issue for all we know. how many PCI cards, cd roms, hdds and what graphics card do you have. you problem could be a power/heat issue. causes alot of lockups.
do a bios clear by shorting a few designated pins on the motherboard with a jumper and then see if that helped. Look in your manual for the motherboard on how to clear the bios using the jumpers on ur board.
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
