i use coolant... car coolant. lol. best temps i would be getting during summer would be from today so ill see how good it runs when theres a great delta temperature, and airflow coming from outside over the radiator.
ah cool mate, sorry I misinterpreted what you said .... Thermaltake cases/PSUs ftw :happy:
I haven't used their water cooling products, but find their heatsinks/fan setups to be very good. I never got into water cooling, always found the idea of water running through my PC way too scary!
yeah you dont have to run water in them as mentioned earlier alchahol/mix has no freezing point and chills more than water
well if u really think about it all u need is demineralised water and something to stop stuff growing in it. Your room would never hit 0 deg celcius to even freeze normal water :happy:
edit/ and as long as it wont react with any metals used in the loop
Edited by Bl4cK32
SAZilla,
What vid card and hows it clock with water vs std air? :laugh:
I've never bothered with water cooling but always wanted to have a play one day..
My overclocking adventures in the last ~12yrs have never seen a failure, I put this down to never using water, even when using a decent hsf heat becomes an issue before volts so your never really able to run enough volts to kill a chip.
im running a 7950GX2 video card, the "sandwhich" card. it is 2 7950 cores x2 on 2 PCBs which are sandwhiched together with 4 tall pins on 4 corners of the boards and a small PCIe interface in the middle of the card that links the two together. I cannot water cool it if i cant fit waterblocks inside the middle of the card and i dont overclock that card at all anyway cause im looking at selling it. the only waterblock at the moment i have is on the CPU cause im kinda trialling thermaltakes product.. the rocket.
last night it was at 33 degrees idle, and 40 degrees load, this is acceptable cause 22 degrees and then like 14 degrees at night is a normal winter/autumn/spring kinda weather on average and i can deal with that... but when the room abience is 30 degrees the idle temp is 48! the load temp 56! the cpus rating is only 60 degrees so its kinda dangerous. I should have gone with a radiator with a fan but i wanted to have no sound but the GFX cards fans. mind you.. my graphics cards idle temp is par 50 and load is 62. my computer runs very hot with these parts inside. last night was the first night in summer that every temparature stayed below 41 degrees and the HDD temps were 23 and 23 a piece (2 SATA2 HDDs 320gb)
performance can be much greater if you select the right equipment, and if u clean everything and install everything properly you will have no issues whatsoever with water cooling and there is no possibilty that anything will go wrong if it is maintained corectly.
Edited by SAZilla
im thinking now about how to utilise a car radiator for my system and a custom pump. i want to mount the radiator outside the house and thru my window run the pipes into the computer and have this driven by a better 12 volt pump thats alot stronger. my mate who has a sil80 said why dont u just intercool the f**ker and i said im not crazy. this is kinda a hobby for me until my case becomes a fish tank.
I toyed with the idea of using an old car heater core (head down to U-steal it wreckers and pick one up cheap).
lol at the car rad idea.. Massive. Keep the shroud attach an old solid radiator fan to an old washing machine motor and your set. :laugh:
it would be easy to set up one from pool just need some long ass plastic tubing and the 12v pump would be enough. ill try it from a bucket tonight and see what happens, at least there is no chance of the lines bursting or caps falling off cause there is no pressure build up
Edited by SAZilla
I was planning to use an old heater core I had lying around. A good resource is overclockers.com with a list of didferent car models, dimensions and inlet & outlet diametres. The articles a bit old but you get the idea
http://www.overclockers.com/tips1031/
I've seen other kits with a 40L plastic bin next to the PC with 2 hoses in it. Worked quite well.
Edited by L3nny
yeh take it... probably just needs some caps changed lol and a new fan.
i just completed the test... the results are clear. i went from 44 degrees idle to now 33 degrees idle after 2 hours of comp being on. my setup is the thermaltake rocket water cooler radiator sitting in a bucket full of water (like an internal resovoir of some sort), then a tube going in the radiator and then from the radiator into the bucket then the bucket into the CPU block lol. lmao i should get some pics up wait on lol. :(
Edited by SAZilla
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
