NOT f**kING HAPPY!
Signed up to 3 mobile broadband as they promised d/l speeds better than my ADSL1 connection at home for a better price.
This is the result:
What a load of f**king crap. They will be getting an earful from me tomorrow
Not happy JAN!!!
Ignore speed tests they are a load of crap.
Dload from a mirror to find out your true dload speed.
That speed test reads lower than what I really dload at by approx 50-80kbytes/s.
Remember you do have a 30day trial if you like to call it that. :blink:
Yep agree with the file mirror thing, the Internode speed test even tells you to do that if you have a fast connection. 2150kb/s here
LOL @ 100m exchange on ADSL2+, too bad you need like 5 torrents going to reach that speed.
lol yeah speed tests arnt too bad an indication but definitely don't hold as gospel
[*Test Results*]
Test run on [*15/09/2007*] @ [*03:01 PM*]
Mirror: [*Telstra Bigpond*]
Data: [*9 MB*]
Test Time: [*5.25 secs*]
Your line speed is [*14.4 Mbps*] (14398 kbps).
Your download speed is [*1.76 MB/s*] (1800 KB/s)
and yes Hillzy M3 isn't easy not like Need For Speed
yeah i know i have a paid subscription to that game :)
support the community
http://www.lfsworld.net/ search Madaz_Rx8 :( thats me with no stats cause i dont play it but can if i want :laugh:
Edited by Madaz
Well, I tried my wireless here at work today (city, east side) and speeds are 800kbps and a download speed of ~70kbps.. Seems the reception is just rat shit at my house :)
So looks like I need to keep paying for line rental and ADSL1 :action-smiley-069:
Unfortunately NO. our house is on a RIM service, ie. it's multiplexed at our suburb before being taken back to the main exchange. This doesnt allow ADSL2+ unfortunatley, but we CAN get ADSL1 (which is something).
I was hoping to can home line rental ($25 per month) and land line ADSL ($40pm for same speed, $65 total) and just pay for wireless at $30 per month, to save some money.
BUT looks like the internet gods have said no LOL.
Edited by Hotwire
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
