:P
Finally.
Went through all other connections. jumpers. etc etc.
Stuffed around with the lot.
In the end it booted up. Im happy. In a way.
Back to the original problem. this soundcard. I think ill leave that for another night.
Thanks guys. I Appreciate it.
got a marshall jmp1 that i no longer use and have been looking to sell for ages
but nobody has the taste to appreciate such fine hardware
make me an offer? :P
-D
Sold mine on ebay about 6 months ago. Mine was mint and I hadn't used it years since I quit playing in bands, from memory I got $680.00 for it.
Great preamps for live use but I found that it had no place in the studio when comparing to a tube amp or ironically something as easy to dial a sound into as Native Instruments Guitar Rig software.
all I can add to the X-fi is that creative cards are shit house
been through too many issues to ever worry about buying one again.
useless useless company
received my asus xonar d2x soundcard 2 days ago, awesome quality and better sound than from creative x-fi fatality pro series
took a while for the pc to recognise it, but oh man music is amazing with the high quality xonar pci-e4 card
Whats a good mobo that is roomy?. and can handle both my gpu card and soundcard
ATM the 9800gt is too big and doesnt leave enough room for the x-fi soundcard to slot in. suss.
something that will take a core two duo 2.4
TBH I've been wondering why you got a creative soundcard in the first place. They used to be the bees knees back in the early 90's but for the last 10 years theyve really sucked...
You should give derringers a call and see what soundcards they sell.... last pro audio soundcard I got was the DSP24 C-Port with 8 analogue ins, 2 balanced and midi controllable (1u rackmount) ... did pretty good for its time, 48khz 192bit, 10 stereo channel recording simultaneous... had ASIO drivers etc
-D
Yeah Ive got a SPEEDIO novation midi input output external thing. Just want something to run nicely with it.
This speedio thing is 48khz. 24bit sound. etc. Gain controls. input gains etc. phantom gain. Made in the UK
im on a roll tonight!!
*cough*invoke*cough*
imo we need to have an sau lan at arena again
seeing as i missed the last one and the last time i was at arena was for GG arena draft
i was just thinking this the other day will organise another one after easter
EDIT
what is folding about ;):)
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
