imo we need to have an sau lan at arena again
seeing as i missed the last one and the last time i was at arena was for GG arena draft
ya, do it! I am putting on new games like COD5, Red Alert 3 and few other 2008 games on arena's machine now...... :yes:
Yeah Ive got a SPEEDIO novation midi input output external thing. Just want something to run nicely with it.
This speedio thing is 48khz. 24bit sound. etc. Gain controls. input gains etc. phantom gain. Made in the UK
I'm not sure I understand why you need the Creative card at all then....
i almost came to see you last friday johnny but started running out of time to go get my daughter from school
it's alright, we got plenty of time to catch up, dont worry! :banana:
should have arena Left 4 Dead lan up!!! such an intense game! lol
mate, u have no idea how many people play and love that game at arena, especially everyone play in "VS" mode, it's soooo f**ken fun, screaming shouting, crying......umm yeah!!!! let's setup a SAU LAN soon! :banana: L4D FTW!
I got Left 4 Dead here too but havent touched it yet...... purchased and downloaded the Valve Complete Pack and have only played about 10 minutes of Half Life 2 so far - even though I've completed years ago... but this time playing on full settings everything on my new computer :banana:
yeah ok ill organise another one but im thinking we just skip the coffee the 2nd time we tried to do coffee failed
EDIT most of u need to go >>Here<< and uncheck Is daylight saving time in effect? :banana:
make sure to click the button at the bottom change my settings
has anyone here changed to win7?
there is a release candidate available now
http://www.mininova.org/tor/2495642
im thinking of giving it a crack, my install of xp is getting a bit tired and thought i might 'upgrade' rather than reimage. have only played with it in a VM so far
gonna run it as a second OS first in case it has a bad case of gay
Looks as though MS have still been looking at OSX... Vista was a heap of shit not sure it's worth d'loading 7 just yet!
im guessing not. i'll be waiting till it comes out in a final version, then i'll buy an i7 cpu and the rest.... screw vista too, xp works fine in the meantime
-D
    • Ah ok. I seem to be mixing it like everyone else does so not sure what's happening. Will experiment with it more.
    • Depends on what you mean by OK. First up, was this done cold or hot? Are they reasonably consistent? Yes, they are reasonably consistent. Could be better. But unless it has had a build at some point, it is a ~30 year old engine and you'd expect some variation. Some of the difference could also be in user technique Is it good compression? Well....not numerically, no. New they were >160 psi. The one at 140 would be fine, in that context. If they were all ~140, you'd be reasonably happy. But the one that is @120 is twice as far down from the original numbers as the one @ 140. But.. (again)... technique can play a part in the absolute magnitude of these numbers, and the quality/state of repair/accuracy of the pressure gauge is not known. In the context of the above, the compression tester that was used last on my car is regularly compared to a known good pressure gauge. Not calibrated, exactly, but compared to a reference instrument that is not used for any other purpose, so cops no abuse. So we can trust the measurements off that tester. But another tester in the same workshop wasn't being compared against the standard and was reading a good 30ish psi lower. When you're reading 100 psu but the engine is really doing 130, you can make bad decisions.
    • More likely from tiny bubbles in the filler/putty. Maybe be less aggressive when mixing it. Perhaps invest in a vacuum chamber to pull the air bubbles out?** **I don't know if this is a thing for body filler. I see hardcore epoxy makers degassing their mixed resin on the regular.
    • IIRC, the speedo on these is fed from the sensor in/on the snout of the diff.
    • They were. I bought the AWD for experimenting but racing it would disqualify or disadvantage me from a few race classes. Def getting a FWD for racing.
