My work laptop (this one I'm on now) randomally without warning does weird shit where the screen goes either black or pink and I lose whatever I might have been working on. Have to force off and reboot and then it works again.
help desk just had my reseat the RAM. still no worky. see what they come up with next.
SO, i connected a secondary screen and ran Primary Hard Disk Self Test, results are "#2 - 07 Fail". HP tells me i need to purchase a new hard drive. I dont see how that affects my display tho?
Can you access anything on the drive, I'm assuming you can because you ran the disk test? With the second screen plugged in can you access Windows or is it not booting from the drive at all?
If so I'd get any or all data off of it while you still can.
Ok so i managed to ferry files from my laptop to work pc via USB. Looking at HDD's, Western Digital 2.5" 250G, $88 from MSY. is this what i need?
yeah but make sure you get the right one (IDE or SATA)
If you're going for a new HDD, get one with high rpm (7200 minimum) you'll notice a huge performance gain on the 5200 rpm drives. Get a Solid state drive if you can afford it. They have the best performance but they are rather expensive unfortunately...
-D
EDIT - I still cant fathom why a hard drive fault would cause your screen to stop working... I smell shenanigans
Edited by Dohmar
RE: your Edit: thats what i was thinking, i asked this from HP help, and they said the OS might control the video... pretty open ended answer. My comp still seems to work fine, maybe ill run Preimary Disk check again to double check.
thats bullshit
the BIOS controls the video until the operating systems driver overrides it. call them up again, cut sick and demand that you speak to someone who isnt incompetent
-D
i got this email back from them:
Hello Damien,
Thank you for contacting HP e-Solutions.
This e-mail is with reference to Service Incident id: 1953674 for Compaq Presario C554TU Notebook PC.
I understand that the display is very dim, but there is display on an external monitor. Also, the hard drive failed the test from BIOS with completion code 7.
The notebook needs to be repaired to resolve the issue. Our records show that the warranty of the notebook expired on 26 Apr 2008 and hence the service is chargeable.
Please provide the following details to setup a service event:.................
So i said:
Hello,
So all I need is a replacement Hard Disk Drive? Or is the screen a different issue?
Reply:
The issue with the dim display can be resolved only by replacing the display panel as there is display in external monitor, but very dim display on the notebook.
Please e-mail us the above requested information. We will be glad to further assist you.
Regards,
Vijayasarathy
Technical Support Engineer-HP e-Solutions
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
