for those of us with rFactor inspect-a-gadget has a dedicated server running all the time to which i has admin :D
download the GTR and the touring car ledgons mods with bathurst and its updates and we can go racing
IP:
>>Touring Car Legends<<
i think Bathurst only needs to be 1.1
>>Bathurst<<
GTR 1.1 mod
>>GTR 1.1<<
you will need to sign up @ rfactorcentral but if you do have rfactor you will go through heaps of downloads as there is heaps of good stuff there :)
for those of us with rFactor inspect-a-gadget has a dedicated server running all the time to which i has admin :banana:
IP:
>>Bathurst<<
GTR 1.1 mod
>>GTR 1.1<<
you will need to sign up @ rfactorcentral but if you do have rfactor you will go through heaps of downloads as there is heaps of good stuff there :bunny:
Just be careful you don't double book the server Steve! JFF use the server too so I should give them a plug and get you guys to check out their site too, they're a great bunch of guys who race regularly and would appreciate new guys to race with...
Check here first before you host a game to see if there is a race or practise scheduled, or join up and race with the guys, they're on most nights racing...
http://jff-racing.my-goo.com/
any time they're not using the server, you're welcome to load up the skyline mod or whatever and any track you like and have a blast!
have fun!
Gadget
with the Nismo 34r mod (the best one to use) I have laid down a 2:08.151 at bathurst.
a 2:07 definitely possible as I'm still tweaking suspension settings and have only done 10 laps in the car so far.
Tips...
1, soften suspension
2, change gear ratios till you can get 308KMh down conrod with rear wing on 2 and front splitter on 2
3, MUST increase brake ducts to as big as you can. Brake fade is a MAJOR problem with brake temps over 1100degrees!!! brake at the kink in the end of conrod, and pump the brakes, brake earlier here, because by the final turn, the brakes don't get enough time to cool and you can end up in the fence with no brakes!
4, use torque split of 35 front 65 rear. or 30/70
5, increase tyre pressures and play with camber settings till you have even tyre temps across the tyres. cold in the middle, add pressure and vice versa.
6, slow in, fast out
7, drive smooth, smooth is fast, don't try to drift, it will, but don't try!
8, raise rev limit to 9000RPM
hope that helps, and gives you something to aim for!
Gadget
Edited by inspect-a-gadget
    • Physically, you'd expect it to turn the motor 11/8ths faster than a standard one, but I'm not sure of specifics
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
