So seems the PS3 finally got jailbroken. Quite ingenious too, a USB dongle that tricks the console into thinking it's a dev unit hence running unsigned code. Whoever thought of that is gonna be one rich guy!
"The good news for jailbreakers is the software the jailbreak runs stops Sony from pushing a system update." - pity I've already updated that stupid patch where it removes "Other OS"...
ugh. got a 360s to replace my dead and gone 360, and ive spent perhaps 3 hours on the line with xbox customer support telling me that i should be able to connect with no problems, and saying that if im having issues, its with my isp.
so ive spent about the same amount of time on the phone with my isp and stuffing around with my router settings and its all come up apples, everythings working as it should.
just finished another call with xbox support, and theyve advised me to get a replacement console...
... honestly, ive owned it for less than 24 hours, that seems a bit retarded.
and fixed.
new xbox's are finnicky bastards. had to disable my MAC filtering and my security, searched for networks again, and connected straight away.
Edited by scandyflick
at what cost though?
and what's the performance like?
For me, I'm actually saving $15/mo on what I was getting previously (and then I was only getting 150gb/mo).
Main differences from my old plan:
i) Uploads & downloads are counted as 'usage'
ii) Split of the 1TB between 500GB peak/500GB off-peak
However, I did the math and even if I max. my outbound the entire month, that's less then 150gb/mo... and ultimately, I'm still saving $15/mo for more downloads - so it's hard to go wrong.
As for performance - it's iinet, their network is one of the best in the country. Hasn't changed from my old plan.
As per http://www.iinet.net.au/broadband/plans.html & http://www.iinet.net.au/business/broadband/plans.html
For residential users, $129.90 - which includes cutting your regular phone line across to iinet (which will probably save you money anyway).
For business users, $165.90 with the above phone line proviso. As a note, naked dsl plans don't have a 1TB option as yet.
Even their lower down plans are pretty decent for one of the better quality ISPs (in terms of service, support, and their network infrastructure). I tend to recommend people stick with iinet/internode if they can. There are definitely cheaper ISP options out there (think TPG), but they have a poor history in Australia for their network, service, quality, etc.
There is always something about people who own Skylines that attracts I.T. Im an I.T engineer, and I have r33... Valid point? haha. I think the skyline brings out a little geek in everyone :blink:
youll find a lot of IT people here, this is true.... common job ;P
-D
Also consider you're going to get a bias of IT people on here given it's an online forum ...
I do find it interesting to see the sheer mix of IT people though - their different skill-sets, roles, etc.
Hardly bias... You don't have to be I.T savy to know how to write on a forum these days... In fact, you have to be just plain retarded not to know. :thumbsup: haha
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
