9.95l/100kms?
That's awesome!
In fact, that's what I was used to in my standard AE92 Corolla (admittedly in city and traffic driving), which is roughly 700kg's lighter than the Stagea...
My best in the Stagea so far is around 12.6l/100kms which was a run from Sydney to Canberra with some Sydney traffic running, and a similar run on the way home with some driving around Canberra before the trip back.
  • Replies 216
9.95l/100kms?
That's awesome!
yes, they are pretty bad on city driving, can only get around 450-470 k a tank with stop start stuff (12.3 -12.8 L/100), but 9.95 L/100 out of a tank on the highway I'm very happy with. Its like a "normal" car, but with all the prestige that comes with a Stag. PS tyre pressures are 42 psi all round too - heavy beasts benefit from more pressure for both handling and economy.
5km to the Litre of Fuel!
ever 100km eats up 20 Litres
Stock 4 door r33 series 1 skyline!
single turbo, maybe 2 never looked lol. think its one though
car drinks fuel like its going out of fashion.
is something wrong?
it got new plugs injectors clean.
EDIT by Ska: Made normal Size
  • 1 month later...
Well I thought I would conduct an experiment.
Firstly I ran my Stag until the fuel light just came on. Then I filled her up to the second click of the pump, 63.7ltrs of BP Ultamite, I usually
use BP cause I can use fuel dockets with them :(
Then run it until the same position on the fuel guage and see how many kms I could squeeze out of it.
So here is what I did:
* NO throttle above 10-15%
* NO boost, well do not let it go into the positive boost range on my gauge. There were times where it did go into the positive, but these were few and fair inbetween and it never went above the 5psi like a spike not kept at that level. I became an expert and modulating the throttle to keep the needle hovering around the 0 mark :P
* RPM match/speed match gear changes, still using the clutch.
* NO riding the clutch at lights.
* NO red light Grand Prix, not that I would, or anyone else here would....
* Driving along the route that was the best compromise between the distance to travell and the amount of sets of traffic lights to encounter.
* Roll along in Neutral when going down a hill, coasting to a stop, coasting along a flat piece of road, and generally when the throttle is not
needed to maintain speed.
* When slowing for a red light, try not to come to a complete stop and leave enough speed to easily accelerate using second gear, not first.
* Make gear changes at 2,500rpm or MAX 3,000rpm.
* Making most economical choice of gears. For example I was using 5th once up to 60kph, but if I encountered a small hill, instead of leaving it in 5th and using more throttle to bring on boost, down shift and use suitable gear that would keep me at the limit and not create any positive boost.
* Not going over 100kph. This was going to be 100kph but had to do a trip to Yeppoon and back, (~50kms), and the limit was 100kph so tried to stay at 80kph until traffic caught me then I would sit at 100kph until an overtaking lane and let all the traffic past.
Considered but did not do:
* Remove front drive shaft so that front drivetrain section did not take any load. Ended up not doing this as I assumed that since I was accelerating so slowly that the fronts would never be engauged.
* Turning off motor at lights or on extended downhill rolls. Ended up not doing this as the light changes were on average less than 45seconds, and turning motor off during downhill rolls could potentially be very dangerous if you had to take evasive action whilst in motion as all hydraulically powered equipment become sluggish. Also I would guess this to be illegal anyway.
* Turned boost down from 10psi. What would be the point in doing this, as I would not be hitting positive boost anyway.
Now about 4mths ago I had Mercury Motorsports do a "economy" tune on the power-fc, so I cant comment on the amount of power I am running, but was very happy with the tune for highway driving as they spent most of the time tuning the 80-100km in 4th and 5th with low throttle positions. Still the high % throttle positions felt great for delivery of power. Not even going to guess how many awkw I have atm.
So after lasting 9 days more than what a usual tank of petrol lasts me here is the results:
Firstly, driving around like normal: 300-350kms/tank (roughly)
Fall of Wickets:
Mark on Petrol Gauge - Km's Showing on Odo
Full - 0kms
3/4 - 134kms
1/2 - 169kms
1/4 - 154kms
E Light - 96kms
For a Total of 553kms out of a tank of petrol, (~63ltrs).
So it just goes to show you just how much you can stretch the petrol out to just by changing your driving technique.
That said, it has been the most boring two weeks of my life, on the drive to and from work :thumbsup:
That's fantastic Ska!
Now you are a bloody Volvo driver, haha, goes to show what you can do if you put your mind to it and wear a very light right foot.
Cheers
Luke
Edit: did a little thinking on this the other day slugging up a hill in OD and noticing I was on boost with low revs and contemplating the revs/throttle position/boost/injector cycle equation... I clicked out of OD and I was back into vacuum all be it at higher revs. A true economy meter would be revs/injector cycle based, boost should be irrelevant but in it's nature is probably a pretty good indication of fuel consumption and efficient driving I guess...
Edited by munchdesign
Best I have got so far is 370k's for a tank (City Driving). This is about 50kms more than previous best of 320. Thats completely stock apart from exhaust mods. Was driving pretty sedately though.
Gotta put on the DFA!!!! :thumbsup:
my best ever tank was 450, which was when i first bought the car, and doing heaps of freeway driving, now with all the mods my worst tank so far has been 274kms... cant wait to TRY and fit my power fc
1. Remove front drive shaft so that front drivetrain section did not take any load. Ended up not doing this as I assumed that since I was accelerating so slowly that the fronts would never be engauged.
2 Turning off motor at lights or on extended downhill rolls. Ended up not doing this as the light changes were on average less than 45seconds, and turning motor off during downhill rolls could potentially be very dangerous if you had to take evasive action whilst in motion as all hydraulically powered equipment become sluggish. Also I would guess this to be illegal anyway.
Some random thoughts;
1. I have had this argument with one of the race team guys, who says we should turn off the 4wd on the straights in the GTR. My response was that since the front wheels, front drive shafts and front diff have to turn anyway, I can’t see how you would reduce the power train losses. Even you disconnect the front tailshaft the front wheels still have to turn, otherwise the car won’t move. So the rear wheels have to transmit enough power (torque actually) through the road to turn the front wheels
Secondly since energy can neither be gained nor lost, it really isn’t drive train “losses” anyway. The kinetic energy is merely being transformed into heat energy. Hence the oil temperature in the front diff should go down if the “losses” are less when the front drive is disconnected (ie; zero hydraulic pressure in the ATTESSA). So we tried it, guess what, down the straight the temperatures were the same. Hence no “losses” were saved by disconnecting the front drive.
2. On overrun the Power FC turns off the injectors (same as the standard ECU), hence as long as the engine is above the highest idle rpm, there is no fuel flow. So turning off the ignition would accomplish nothing (in the way of fuel saving) until the engine reached idle rpm.
:no: cheers :D
Fall of Wickets:
Full - 0kms
3/4 - 134kms
1/2 - 169kms
1/4 - 154kms
E Light - 96kms
Man SKA, 96 km on the E - light, thats nerves of steel. I fill mine back up once it gets there and we've never put more than 58 litres in the thing, ever.
Sorry should have made it a bit clearer.....
The readings were taken when that mark was reached, so from the 1/4 mark until the E light came on was 96kms.
I can only do ~30kms on my light, I have done it before, and conked out :)
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
