1998 Er34 GT-T Sedan
2.5 Litre NEO6 Turbo engine
4 Speed tip-tronic auto with steering wheel shift
73,000km’s
LSD
Super HICAS
ABS
Airbags- two in the front and 2x side impact
Traction control
All power options
3.5inch Blitz Nur exhaust (plus silencer)
3inch Turbo dump and front pipe
600hp Hi-Flow CatCo Catalytic converter
Pod filter
600x300x76 front mounted intercooler
Profec A Electronic Boost Controller
Turbo Timer
SAFCII Black (Tuned by Hyperdrive)
Xenon lights with adjustable tilt
After market stereo with MD player (jap one ie shitty radio) and Alpine Type R subwoofer
Serviced every 5000km’s with Mobil 1 and replaced plugs with iridium’s
Power output of 250rwhp @ 10.5psi. Was also tuned richer than most people get to keep it in the green.
Stock exhaust and filter still in garage. But stock IC has been sold. Comes with spare tyres 4x Bridgestone G-Grid IIs with lots of tread left (taken off for compliance).
Now replacing rear bumper...
Cost of ownership...
$901 a year in insurance and im 22 with 60%NCB.
Costs about $60-70 to fill with BP Ultimate and gets between 450-550km's depending on how its driven.
Servicing costs about 70 bucks every 5000 (im sure you can do it every 10 but I wont)
Asking 23k ONO
PM or email... [email protected]
*Added more pics*
Edited by SnRuB
https://www.sau.com.au/forums/topic/109261-r34-gtt-sedan/
the missus wants that auto :O
I must stay strong for the manual... :ninja: hehe. good luck with the sale.
btw...got pics of that crack in the bumper?
Edited by mickey
https://www.sau.com.au/forums/topic/109261-r34-gtt-sedan/#findComment-2073244
the missus wants that auto :laugh:
I must stay strong for the manual... :D hehe. good luck with the sale.
Yeah i know where you're coming from. Same thing, just 12 months ago :-)
My cameara is stuffed so im in the process of buying a new one. But to describe it.... Its the right rear corner. It went into my other car at about 2km/h and is more warped that it is cracked. A few people said i could repair the crack and get it sprayed but a new kit and spray is only 1k more than getting it back to stock anyway.
Let me know if she wins and you want to talk..
Ben
https://www.sau.com.au/forums/topic/109261-r34-gtt-sedan/#findComment-2073844
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
