Whats the story with this?
Ive heard its illegal to have xenons on R33s cos they are not factory... no offence but stock headlights on R33 sucks balls... they emit an ugly yellow light and often the actual headlights go all yellow and need cleaning.
Im about to get an R33 and want xenons on it... :mad:
https://www.sau.com.au/forums/topic/109767-r33-xenon-lights/
Yes they are illegal because they are not factory but I have not heard of anyone being defected for it. Just don't get some insane blue (8000K+) HIDs and it shouldn't pose a 'pull-over' problem.
Or if you want it as close to legal as possible, source some Series III R33 GTR lights which have factory projector HIDs. A set is pricey though, around $1000 used bought from Japan's Yahoo! Auctions.
Yeah you can get some HID kits from group buys for about $220.
As wink said, stick to white, and you'll be fine.
Legally, cars with xenon have to have self-levelling headlights for obvious reasons. If you put xenons in your standard headlights, it will be illegal, but 90% of the time, you wont get defected for it.
HID's are illegal unless the suspension is self-leveling... not quite sure how that works...
You can just put some decent philips halogen bulbs in your stock lights and they come up good. Only the older light plastic covers go yellow, the nice cars usually still look nice and clean. (its only the Series 1 GTS and GTR lights that go yellow, series 2 GTS are different).
You can put a HID kit in... not sure what i think of those...
The Series 3 GTR came with xenon's ... they are rare to buy 2nd hand, you can get them from yahoo japan sometimes, very rare that you'd get them landed here for much under 2k...
as for illegal to have lights that you can adjust thier level????? I doubt it since most cars have an adjustment on the headlights to get them set to a correct level.
Oh ok, yeah you guys are right, it's self levelling suspension.
I was getting confused as my Lexus RX330 has self-levelling xenon headlights which move around as you go up a hill or around a corner or whatever.
It is illegal to have lights which you are able to move its position.. am i correct?? thats what i heard!!
like on the r34s, you are able to move the position via a knob or somesort..
Dunno about the R34, but my old man's BMW has manually adjustable headlights.
The lights must be self ajusting and they must have washers to comply with ADR.
The series III 33 gtrs that were imported under the old system were complied with the xenons legaly but under the new system you cant comply them unless thye are self ajusting and have washers .
All plastic h/lights go hazy / yellow in japan of course the older they are the worse but i have seen even 34 lights like that but not as bad as some 33's.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
