I have a pair of R33N1 turbos for sale . I had these in my old R33 ( burgandy GTR33R for those of you that knew the car) She ran 11.7 @121 mph @WSID . The only other mods, full exhaust ( stock dumps) power f/c and boost controller ( 1.2 bar ) . I have sold the car and i was going to install the turbos in my 34 but i used GTSS' instead . The turbos were rebuilt by Garrett before i put them on the car and all up have done less than 10,000 km . I still have the receipt from Garrett for any interested parties and they are in perfect condition.
SOLD
Edited by wrxhoon
https://www.sau.com.au/forums/topic/109781-sold/
I'm looking for $1750 for a quick sale, located in Sydney but will post at byers expense, about $40-50.
P.M., post here or phone 0408 973245
can i have part# please
https://www.sau.com.au/forums/topic/109781-sold/#findComment-2022662
hi wrxhoon, can you tell me what size housings they are? are they the .64 ex, .60 comp, or .64 ex, .48 comp? and bearing type?
'They are the big AR60'S group A turbos and they are sleeve bearing.
I will try and get some pics posted on here .
https://www.sau.com.au/forums/topic/109781-sold/#findComment-2023318
How many kw did you get at the wheels with those turbos on 1.2 bar
TRhat would depend on how happy the dyno would be on the day , thats why i put up the 1/4 mile et and trap speed, go around the the drags and see how mny gtrs will do 121 mph with the mods that i had .
https://www.sau.com.au/forums/topic/109781-sold/#findComment-2025690
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
