Hey,
on the way home last night i was just cruising at 85km.h down straight road when the HICAS warning light came on the dash.
After a while of this not going out,, i pulled over turned the car off, i then looked under neither, all seemed fine to me. the fuse in engine bay was fine aswell. i started the car back up and the light turns on after 4-5 seconds.. and after turning it of a few times, the lights wont go out..
Basically, is someone able to suggest why this light is coming on? and is there anything i can do to fix it?
any help would be great.
Thanks
https://www.sau.com.au/forums/topic/109969-hicas/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
