i have a a r34 rb26 in need of a rebuild and need help!!
the car it is in is a ex D1GP car and is obviously used for drift.
it has run a bearing (1 or more) possibly due to oil surge
anyway it is now due for a rebuild, we were atleast going to go
pistons, rings, rods, n1 oil pump, trust extension kit, is highly likely we will need a new crank
as we realised what was happening quite late ( can't hear anything over the 3 fuel pumps)
we were going to go with the first stage hks 2.8l kit but evidently the block wouldn't like it
and we would need an N1 item, so that scraps that idea also we were told that we may aswell
throw the engne away as bits of bearing would be scattered throughtout the engine (i thought a good flush and tidy up/porting would be sweat!)
any way what options do i have with the crank, scatered metal in the engine, etc.
ps we are looking for around 600-700hp rear wheels (we have all the externals to handle that and more!)
cheers
https://www.sau.com.au/forums/topic/110005-r34-rb26-rebuild-time-drift-spec/
yeah 450-500kw drifter
it is nuts already but hey can never have enough and since it needs a rebuild anyway
it did a team event with kuroi at an option 2 event in 2004 i think,
anyway, do i need a n1 block for 450-500kw? with a stage 1 hks 2.8l kit?
what are my other options with the crank what is good out there and what $$
any of you guys that has had an rb26 expire in the same way have any problems
with debris through the engine?
ohh and yes it is a four door
cheers guys
might even post a pic of one of the laps before it let go
cheers guys
u got jun 2.7L billet, full counterweight crank, tomei 2.8L (not full counterwieght i dont think) and the hks 2.8L crank, though there a few different hks cranks in the 2.8L depending on power. and n1 block is only 3K i was told which if i knew when i did mine id be using one str8 up, not worth risking on a normal block when they are sooo cheap :down: plenty of options around, try searching the site for stroker kits as their was a large thread on it a fair while ago now discussing all the options :(
show us some pics :( is it a skyline or a chaser going by the jzx (rb26 powered) as your listed car?
at the time it blew it had 334kw rear wheels and 1100nm of torque but that was detuned running pump gas.
the head has all the bits (may be looking at new cams if debris got up there though).
Was told that the r34 block was basically similar to the n1 in design ( with extra ribing for greater torsional strength stopping cracking in the block at hi rpm) , would be going for the first stage
2.8l kit the second and third is a bit overthe top
yeah its a mark 2 toyota powered by a r34 rb26
350rwkw is a much smarter, cheap and more reliable approach than 500rwkw.
plus drifting is more about car setup than power.
personally stick under the 400rwkw marker, far better response and throttle control can be achieved. And thats what you need correct?
yeah decided 500kw is a bit over the top but would like 400kw, the power hits in an awkward time for me anyway and was going with the stage one 2.8 kit (highest compression version) to move the torque down in the range a little bit with a bit of response (would this be the case?)
as for the power in drifters issue have you seen kuroi's 900ps onevia powered by rb26, but yeah i do agree
does any one know if the r34 block is similar to the n1 in design ( with extra ribing for greater torsional strength stopping cracking in the block at hi rpm)?
btw the track is in NZ pukekohe infact (mega entry speeds into that sweeper!)
my work brought in a 33 gtst x Garage Aqua track car from Japan with r34 n1 crank, rods and oversized pistons stroked the 25 to a 2.7lt its fitted with a RX6 made 355rwkw on flat out mode i.e 1.8 bar
Its super responsive span the semi slicks up in third without any problems on 1.2 bar.
the guy that bought it drifts it on 1 to 1.2 bar so just on 280 - 300rwkw plenty of power
R34GTR (RB26DETT) block measures up exactly the same as an R32GTR N1 block. Personally I think the N1 block is under utilised in a 450 rwkw application, a standard block will handle that easily.
My 20 cents…….
Dismantle the R34GTR RB26DETT, clean it up and work out exactly what it is that you need to replace. Then get on with the rebuild stick a standard crank, some good rods, bearings and pistons in it and control the oil temperature and flow properly. It will handle the power you want easily and with a decently ported cylinder head and 9 to 1 compression ratio it will have all the response you need. Ceramic coat the piston crowns, the combustion chambers and the exhaust ports for the superior temperature control and a further improvement in response.
:P cheers :)
thanks Sydneykid, i thought the 34 block was similar and could handle over what we wanted, will
look into your suggestions engines in the process of coming out at the mo.
one of the strong reasons we were looking at the hks kit is that it would only be alittle more (not much at all) to get it than get all the bits and a good stock crank :P
(over here anyway)
still cant belive it had oil surge after competeing in d1gp and other japanese events
only thing i can think of is they ran it over full?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
