:happy: hey guys was wondrin if som1 can help me?? Ive got an R33 GTS-T 1993 just about as stock as u can get! Its got a pod filter stantard exhaust with a canon. Problem is ive put a bleed valae in runnin 10psi,if i tromp it it goes hard but then carries on a bit like its hittin rev limiter!!! Bit confused!! Any help would be gr8!!!! cheers
https://www.sau.com.au/forums/topic/110494-wots-going-on/
With stock exhaust i would turn down to 8psi + how do you no you r only running 10psi?
do you have an after market boost gauge?
the popping you are getting could be plug gaps or computer fuel cut
DO YOUR EXHAUST SYSTEM FIRST
james
https://www.sau.com.au/forums/topic/110494-wots-going-on/#findComment-2035703
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
