Hey Guys,
Everyone Been good help on here so far and got me through,
This time I have tryed so much and no luck so far.
My R33 drops idle intermitently and then cuts out, on idle or even driving.
The car seems to drive fine then jsut looses power and then drops to low idle and drops out, then comes back after bout 20 seconds.
I have replace :
1 Fuel filter
2 spark plugs
3 o2 sensor(with a new 3 inch dump pipe.)
I starting to run out of ideas.
I had a performance company lookat it and they new crap all. i won't mention the company name yet.
I thinking all that left maybe be fuel pump or somthing.
It only happens everynow and then, and is now happening more often.
I have minimal mods. basily increased boost the biggest.
Anyone have any ideas please let me know.
I to the point where i might have to get a machanice with a diagnistics system look at it.
Any help or ideas is a help.
It starting to cost me too much,
Thanks Rob :(
Sounds like what my old vl did. Ended up being the crank angle sensor. Just a stab in dark.
Thanks mate, any feed back good feed back,
Could be, wat the crank angle sensor do, and how much to fix that u recon ??
Thanks dude
Robz
It's a distinct possibility, but I would have thought u'd have trouble throughout the rev range too if it was the CAS, however depending which 1 of the two reference signals is dying you may get away with a few extra revs. If the other dies though, u'll have nothing. Is it happening more when it's hot or on a hot day out of curiousity?
Hey Electro, well it mainly happens after a drive after it has warmed up, or more when i have given it to her, less likley to do it if i go real easy,
so yer coudl be wat u thinking, it has a los of power over normal rev ranges too, it not like it ment to be, that wat i getting at, i always throught it was fuel or air related, so i minimissed that and done wat i can, so looks like could be some sensor.
any more info/input is all good,
thanks mate
:P
Starting to sound like a pretty good chance that's ur problem. Also if you shut it off for a few minutes to heat soak & then try to start it again but have trouble then I'd place very high odds on it.
It's usually under heat that they fail, & sometimes it is intermittent, electronics & heat are a real pain when combined.
If you're worried that you are going to waste ur money on a new sensor though, take it to a deacent auto elec that specialises in EFI technology & make sure he has all the equipement (IE occilloscope and diagnosics equipment to plug into the ECU) and make sure he know's what he's talking about. If he doesn't have any knowledge of Nissan CAS being a problem then run.
hey guys,
thanks for all the input, i today have just taken to northside EFI at brendale, and he got all teh gear to test it, i told him wat i have done and explained wat u guys recon it could be.
hoping he will find and won't cost me the earth.
:( heaps hey
rob
:P Hye guys,
Problem at conclusion and all solved now.
My mechanice who did the best job( Ron at Northside EFI at Brendale)
found that is was the Air Flow Meter, and my fuel pump was playing up too, not holding presure.
So the main problem being teh AMF, i sorced one down second hand, from Driftking at Geebung for mad price. put on tonight and the car goes harder and better that before.
Thanks everyone for your help.
I have spend some money on it, but i got there, got a car full of new components now.
Cruise on boys
Thanks
Robz
Cool good to see u got it soughted out. I had forgotten that the AFM is a common problem with 33's. Reckon I'll be getting a Power FC & pissing off my AFM all together if it starts giving problems on mine. Will replace it with a MAP sensor.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
