Gary, didnt you trade someone suspension for sideskirts?
The problem with the dayz kit is they are rare to come up on yahoo, and when they do they are for S2's! :drag:
Currently though, id rather just spend $$ on other stuff...so i can wait but ill let you know.
  • Replies 143
Posted Images
The problem with the dayz kit is they are rare to come up on yahoo, and when they do they are for S2's! ;)
I had a deal stiched up, but he bought an S2 and sold the S1 with the DAYZ kit on it. No problems, I will find one.
:drag: cheers :D
hey ams, im not really interested in a full kit at the moment and for atleast another couple of months minimum, as i need soo many bits and pieces that are more important.
any chance of a price for just the side skirts and a good pic of the side skirts if possible (besides the pic on the monkey warehouse site)?
thanks mate
Brad
Full kit (excluding wing) will be $1100 plus freight
Was that intended for me?
DAYZ side skirts and rear bumper only?
:D cheers :D
Everything would fit except the front bar, the grill's and lights are different.
has anyone actually checked this or is it just a rumor that keeps getting passed along?
by looking at photos and comparing it almost looks like the front bar would fit but the grill on the s1 is definately taller than the s2...you can tell because the bonnets are completely different between the s1 and s2's
i suppose if you measured the widths of s1 and s2 grills and if they are different widths then the front bars would not be interchangable
  • 3 weeks later...
distance between bottom inside corners of the lights on my S1 is about 830 - whole heap less. which is shite cos i wouldve loved an s2 grille with those lamps...
and here is my car with the monkey warehouse nismo front bar. you'll see its a lil bit different to the pic, was modified at DMD Image. you can see it sits a whole bunch lower than the rest of the car.
we're trendsetters, ega4it. front bar, wheels... and thats all... rest to come.
Fellas, i know i havent been on here really since i got the stagea about 8 months ago but the pintara has been keeping me more then broke and stealing all my time, but thats on its way out the door now and i'm really desperate to buy a kit for my S2 stagea before motorvation january next year.... to get some rep happening... maybe get some of the other WA stageas along, anyways thats for another thread anyone please please let me know of any kits that are available for s2 in perth
IF these kits can come for an s2 please let me know too
ill most likely be in for motorvation next year for sure if mines sorted by then :angry:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
