Is anyone going to Easternats this year?? im thinking about entering just to have a bit of fun on the track...
I am thinking about entering i had a few mates enter last year but they had a few troubles with the police soon as they see you drive out of the course, they see the sticker on the window and pull u over
https://www.sau.com.au/forums/topic/111221-easternats/#findComment-2050066
Al, im trying! Ill start coming to the track days as well, ive been getting the car setup and im nearly there!
I went last year to Easternats in a mates car and it wasnt to bad, your right about there being a lot of people but i really just want to get out there and abuse my car! since my new found power it is really hard to open it up on the street...
Im really just going for a laugh...
https://www.sau.com.au/forums/topic/111221-easternats/#findComment-2050936
if anyone goes keep an eye out for a purple VLT called "FATPSI" pretty wicked paint on that thing
I have seen this car booting around in my area i think... if its the one i am thinking about the driver is the biggest cock head ever.
https://www.sau.com.au/forums/topic/111221-easternats/#findComment-2054494
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
