jee tee - ah yes i waved back !! good effort mate, just drop yer 60fters and you'll be right :D
i dunno how im getting 1.9 60ftr's! but mine just loses top end speed/power. hmm...might need to change gears faster :)
r32 gtst pretty much stock 15.4 @93 mph that was my first time out. should go beta next time
Good stuff burnsie, great to see you out there giving it a go !!
:D
as people say "watch this space"as I know your times will drop (and mine again hopefully !)
Daniel Beers 33GTST, RNMENC : 11.75 @ 121
Adrian Hodgsons 33 GTST 2RISMO : 11.68 @ 117
Sau Nsw 400m Registry
GTR
DiRTgarage: 10.36 @134mph r32 gtr (two.06l stacey 11.95 @121 mph)
SCOOP: 10.9 @ 127.40mph r32 gtr
T04GTR: 11.7 @ 116mph r32 gtr
wrxhoon: 11.8 @ 117mph r34 gtr
JET-32R: 12.49 @ 106.66mph r32 gtr
Morgs: 12.53 @ 111 mph r32 gtr
GTRsean: 12.5 @ 116 MPH r32 gtr
GTR-27L: 12.7 @ 105mph r32 gtr
benm: 12.7 @ 112mph r32 gtr
GTS-t/ GTT
MR331307: 10.8 @ 128mph r33 gtst
DoughBoy: 12.0 @ 123.7mph White car r33 gtst
DoughBoy: 12.1 @ 119mph Black car r33 gtst[/b]
88silhouette: 12.119 @ 111mph r31 sil
OFENSV: 12.175 @ 118.14mph r33 gtst
legend01: 12.220 @ 111mph r32 gtst
qwikky: 12.3 @ 109mph r33 gtst
moanie: 12.504 @ 112mph r33 gtst
ECR033: 12.619 @ 116mph R33 gtst
mass iv: 12.91 @ 111mph r33 gtst
Guilt-Toy: 12.98 @ 108mph r33 gtst
yogi000: 13.1 @ 108mph r32 gts
spx25t: 13.354 @ 103.23MPH r31 25t
abobob: 13.405 @ 103.17mph r34 gtt :D
race_snooze: 13.4 @ 111mph r33 gtst
cerci: 13.522 @ 103mph r33 gtst
silver gts-t: 13.62 @ 103mph r32 gtst
RedDrifter: 13.7 @ 105 mph r32 gtst
JAS-25T: 13.8 @ 99mph r33 gtst
Shonen: 13.934 @ 97.4MPH r34 gtt
SECUR1TY: 14.003 @ ??? r33 gtst
JeeTeeEss25Tee: 14.01 @ 100.58mph r33 gtst
nath95: 14.04 @ 99mph r33gtst :yes:
GTShortie: 14.290 @ 104.24MPH r33 gtst
tomm0: 14.3 @ 98mph r33 gtst
raz0r$harP: 14.516 @ 95.98mph r33 gtst
evil_weevil: 14.5 @ 94mph r33 gtst :yes:
sindows: 14.8 @ 96mph r33 gtst
burnsie: 15.4 @ 93mph r32 gtst
Other
ido09s: 11.274 @ 121.79mph S14a 200SX
bmxwrx 12.59 @ 109mph MY00 WRX
wokburner: 13.02 @ 109mph 300ZX TT
PORTS: 13.433 @ 105.39mph z32 300zx
:yes: = improved on PB
Will be updated regularly. :P
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
