r32 gts-t stock 14.234 qtr 1.989 60ft 99mph best run last wensday
for a stock s**t she goes hard .. :unsure:
http://www.badgerphotography.com.au/SM%200...s/120907172.htm
http://www.badgerphotography.com.au/SM%200...s/120907174.htm
youtube vid up soon nothin special but felt like a great launch and looks good from a stockie :P.
also what are the good times from stock r32 gts-t ?? mate did a 12.8 in a r33 gts-t with 270+ kw so for a 160kw stock gts-t it felt good
will post up time sheets and dyno chart soon:D:D:D:D
Edited by MRDeanos.
  • 3 weeks later...
