Hi,
Im looking at getting a daily driver, with the option to turn it into a track-car later on (2years+)
I am looking at getting a Dr30 or AE86 (jdm not aus spec).
Basicly im looking at the cost to run both cars and how hard it is to find parts for them? I know with the 86 you can go to your toyota dealer and get parts from them and find parts here very easy but im not sure about the dr30.
any input would be nice
ohh what what type of fuel would i need to run in the fj20? bp98?
thanks michael :)
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/
heaps of parts for either, just depends on if you want a bigger car or smaller car. DR30 would be the faster car for track work. IMO if you really want a sweet track car(grip race) get a old scool Rotor RX3, RX2 RX7 even! With the right setup they go hard, just look at the field in Improved Production! But definatly the DR as a street car!
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2052116
Parts for a DR30 aren't very expensive (except oil pumps) and my DR30 was far nicer than friends AE86's. Definitely go the DR30, indestructible engine as long as you keep the sump off the oil pickup, tough rear end and it doesnt have a trailer axle in the back
hey adam, where do you get most of your parts from? do you have to soruce them from japan or can u get them from nissan? (im not general parts which wear over time)
and thankyou everyone else for the reply :happy:
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2052356
ae86's are rust heaps, i own one (oz spec upgraded to japanese rear and silvia front). I also work for an importer and only 1 out of 10 ae86's we inspect that are cheap have acceptable amounts of rust. Usually their owned by budding amatures with small budgets in japan, so maintenance is not a priority. The ones that are well looked after and clean are owned by proper enthusiasts and a good clean runner will cost you at least 12k to anywhere up to 23k for fully restored ones. For that sorta money you can easily land an R33 GTSt that's 10 years newer.
In comparison most DR30's we look at have easy lives and aren't as neglected.
Purely from a value for money perspective, I'd say go with the DR30... you just don't get as good a car if you bought an AE86 for the same amount.
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2052516
thanks for that funky :D
i've been checking out some of the auction in the area which the person i am importing through uses, and their are alot of ae86 but as you said the auction sheet always mention rust...
only problem i have seen is that there arnt many dr30 for sale
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2052547
Go the older model DR30 sedan.. As far as I'm aware body panels should be interchangable with Aus spec MR30's.. FJ and GZE are both awesome engines... Steering feel will be slightly better in the 86 due to R30's running steering box. Then there's the DR's indipendant rear wich seems to work well even though its a trailing arm set up. My mate uses premium with no hassels
DR30 as a daily for the win.... nothing like the oldschool grunt of the FJ when you knock it back a gear :D Bang for buck u cant loose
What sort of figures are you looking at for a clean DR30 landed if you don't mind me asking?
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2052601
Engine parts are easy through Stewart Wilkins in Sydney
Other various bits I've gotten through Jaustech for DR30 specific items, and general Nissan wreckers for common R30 parts
And I had most work done by my Triumph mechanics, so they can't be too hard to work on, they'd never seen one before
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2055818
Mikey, I've seen DR30's with immaculate paint (still stock colour) for around 5k. Sure, it could have a few problems but if the original paint is that good, it goes to show the quality of a car.
FJ20 is the founder of nissan 2ltr turbos really.. And it's a bulletproof beast to boot.
DR30 FTW!
https://www.sau.com.au/forums/topic/111290-dr30-or-ae86/#findComment-2062226
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
