So looking at the SK pic, in standard trim, the subframe floats up and down on those mount points, and the pinapples fill a that gap.
If you get Aluminum ones, sound is tramitted through the frame.
For all round performance use the bottom ones (non split)
For drift tilt the diff back using btm front, top rear.
For drag tilt it forward using top front, btm rear.
"I have the otomotto kit and i have 2 large split and 2 small non split"
This would be a kit designed for drag then.
The whiteline doesnt have the scope for drift? and if you put all 4 budshes in the rear it is a marginal drift setup?
EDIT! The whiteline doesnt have the scope for drag?
couldn't remember if you had the pinapples or not but from memory your car was quiet, handled awsome and had the same firm ride in a straight line as mine with its standard springs and uprated shocks (on car when bought). Cheers for letting me know you did have them for our spin :thumbsup:
P.S. enjoying the job? had to do a couple of your call outs. Sick of being told "can't make it" yet?
Edited by ellie
Not so, you put the small split rings above the subframe at the rear and the large non split below the subframe at the front. This give max antisquat which reduces the rear end grip, making it the ideal setting for drift. It's the bottom left hand drawing in the instructions.
:thumbsup: Cheer :)
I have most definitely used the drag setting (maximum squat) on a few cars that I have worked on, as well as my own. The usual improvement in 60' times is 0.15 second from the subframe alignment.
That setting is the lower left in the instructions (maximum traction). With the small, split rings on top at the front and small, non split rings on the bottom at the rear.
:( cheers :)
most people i've spoken to using them in drift cars, go for either "All Round" or "grip"
As someone mentioned above, and has been confirmed with a few people i've spoken to who have used them in "drift" setup, they are stupidly slippery and becomes more of a hinderance than a benefit if the car is properly set up in the first place.
Any problems with understeer or problems loosing traction for drift should be overcomed using different wheels/tyres or different stabiliser bar settings.
how long generaly should the whiteline pineapples last for ??
i got mine about a year ago but i think there starting to die now...
that clunking noise has kinda come back now when i turn and stuff..
hmm maybe ill take em out and see if there cracked or something
  • 1 month later...
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
