Hi
Have a highly modified R32 GTR that iam thinking of selling want to see if there is any interest for at the price iam wanting to get, car located in sydney.
Imported by me so iam the first owner fully registered with 12 months rego as just got it re-done has only done 8000km since being in australia. Here is list of modifications. Always serviced regulary with Motul oil always replacing fuel filter with every change. Gear box and Rear Dif Oil just done with Lightweight Shock Proof and Motul FFF LSD.
Dynoed at 20psi 360rwkw, 300rwkw at 1 bar tuned by JEM, these are safe tunes as its used as a daily driver.
96,000K on clock
2.6 litre twin turbo coupe with anR33 GTR engine and Trust 618z turbos
ENGINE AND ELECTRONICS
APEXi Power FC and FC Commander unit
HKS EBC
Forged Pistons
TOMEI 260 degree cams
TRUST adjustable cam gears
HKS 1.2mm head gasket
HKS metal gaskets for plenum and exhaust manifolds
Sard 680cc injectors
SARD fuel regulator
N1 water pump
HKS delivery pipe
Bosch intank 044 pump
Polished Plenum
Oil catch like the powerplay ones + oil Air separator
Cusco Intercooler Intake pipes with Custom Turbo Intake Pipes (aluminuim)
Custom Carbon Fibre Air Box with CAI
Cusco master cylinder brake stopper
Z32 airflow meters, new apexi pod filters
Dual core radiator with cusco air panel diverter
TRUST dual core Intercooler 75mm
TRUST oil cooler and oil filter relocator Power Enterprise magnetic oil filter used
OS Giken twin plate clutch with lighten flywheel
R33 Brembo brakes front/rear with Earls braided brake lines F/R
NISMO circuit link suspension parts
AS - front pillar brace bar, for more rigid chasis
Chasis has been Pop Riverted for extra rigidity from engine bay to front cabin
Adjustable Front Upper Arms (camber)
G4 - Height and dampner adjustable suspension
ARC adjustable castor rods
Rear HICAS cancellation bar
ARC front and rear strut tower braces
ARC front and rear sway bars
NO ABS
TRUST dump/front pipes
3n1/4 inch Kakimoto stainless steel exhaust
Hi flowed Catco cat converter
Push Start Button with kill switch
Battery relocated to the boot
RWD toggle switch made by Dirt Garage
GReddy Electronic Boost gauge and HKS oil temp gauge
4WD controller by Raceworx installed (Duncan)
Turbo timer
Trust Gear Knob
3point immoboliser with auto window lifter, works with turbo timer
Rays Engineering 17x10inch rims, chrome outter and gold innner 2 piece rims 255x40
N1 front bar with front lip on bonnet (carbon fibre)
N1 head lights
N1 lip on the boot
N1 style side skirts
Kenwood MP3 player with Clarion 6inch splits, Clarion 6inch rear speakers
Looking for 30K mark
Edited by godzl1975
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/
anymore pictures of the body and interior? idea of wat sort of power its making?
will have more pics of body soon...will put em up as soon as get the skirts on etc....making around the 570 ps mark..not sure how it is converted back to kw..anyone?
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-2072857
570ps!!??@ all wheels or @ rear wheels at what boost?? thats 570x 0.7355 = 419.235kw
Thats up there for 2530 turbos but has been done by Paul Deimar
G Luck with the sale
dont think 570 ps at the wheels....i will be getting it dynoed soon..so will post up then.
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-2081936
  • 11 months later...
Hey Aaron,
Still very interested! I have the cash and want to buy it after the compression and leak down test as well as the NRMA inspection and mechanics report.
I will pay for all the reports and documents as well as the time you took to get car there and back so your not out of pocket or time.
Please answer your PM's so i know whether or not to stop looking at other GTR's. Looking for a car and want to buy pretty much immediatley.
If something else jumps out like your car i might consider buying it if i cant get a response.
Thanks and let me know
Jake
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-2994244
sale is quite old but Aaron PM'd me a few weeks back within my WTB ad for his car.
Negotiated for a week or two and pretty much agreed to a price if mechanics report, NRMA inspection and compression test came up healthy.
Since i asked for these i havntheard from him. Which isx sad cause his car has everything i want in a GTR.
Hopefully he has a read of this and gets back to me and i am looking to buy a car very shortley.
Would love a GTR but if i cant find one that i love then i might buy a S15.
AARON HIT ME BACK or i have to look for a S15.
Anyone that has a GTR like Aarons please PM me as i am looking and i have cash in hand right now!
https://www.sau.com.au/forums/topic/111758-fs-r32-gtr/#findComment-3008509
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
