garage cleanout time
r33 s1 rear pod--drivers side 50$ -SOLD
r33 s1 cam gear/timing belt cover 50$
r33 s1 plenum + crossover + turbo pipes 100$ -SOLD
r33 s1 standard computer 200$
r33 s1 dash 80$
r33 s1 radiator + shroud 100$----sold
r33 s1 coil cover 20$
s1 rb25det cams 200$ --SOLD
r33 s1 floor mats front and back middle mat 80$ -----SOLD
r33 s1 bonnet wine red 200$
r33 s1 wing 100$
r33 s1 drivers side mirror 80$
r33 s1 washer bottle 30$
r33 s2 air box 50$---SOLD
r33 s1 right indicator 20$
r33 s2 steering column 2 pak silver 60$
r33 s1 exh cam gear 50$
r33 s1 right back seat interior panel 50$---cloth trim removed
r33 s1 left side back floor matt 10$ cant find other one yet...
r33 s1 standard side winkers 30$
r33 s1 clock demister hazzard sidemirror controls 50$
ignore circles in bonnet pic...shitty flash on cam..
Edited by thizzle
https://www.sau.com.au/forums/topic/112054-r33-gts-s1-s2-garage-cleanout/
What colour is the drivers mirror? is it convex or straight glass?
the mirror is gold/green but its been scraped off a bit as u can see the wine red under it...
i couldnt handle havin no mirror while it got repainted so i bought one from sss auto..its glass.
Edited by thizzle
80$ cuz i cleaned all that film that peels on s1 off it so now its perfect for paint
all vents included plus buttons + clock are round some were 2..
60 just for the dash if u pay shipping
Edited by thizzle
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
