I'm doing a manual conversion in my Stagea, and i'm trying to find out what flywheel i need to get.
I've got an R33 GTR gearbox on the way, so it's gonna have a pull type clutch in it.
The question is, will the R33 GTR pull type clutch fit onto a R33 GTST flywheel? and vise versa.
Or will i have to get a GTR flywheel (RB26)?
Any help would be appreciated.
https://www.sau.com.au/forums/topic/112504-flywheel/
All sorted, talked to Jim Berry, and he straightened everything out.
and the answer is....?
(not for me, I love my auto and will never get a manual again, but for those considering the auto-manual conversion).
https://www.sau.com.au/forums/topic/112504-flywheel/#findComment-2075636
