hey guys.
my names ben and i have just got my first Skyline.
Sold my Subaru and havent looked back....in the 48 hours i have owned it anyways.
Its a R32 4 door GTSt.
Light blue in colour.
Gay chrome rims
Has a Carbon bonnet and GTR grill (Thank you X-Rated).
Did a tade for it on my subaru and cash adjustment so i had plenty of $$$ to mod it.
Car has been around for a while...most ppl will know it.
Going to do a fair few mods in the coming weeks.
all ways keen for a good cruise ir track day.
will post up pics tomorrow.
cheers
benny
https://www.sau.com.au/forums/topic/112532-new-guy/
Welcome to the wonderful world of Skylines, mate!! ;)
Now you know that GOD exists.... (...turns out, he is a japanese guy, working at Nissan)
Welcome Benny! Looks good, can't wait to see it in the flesh! May see you tonight!
Todd
Hey CAT! Anywhere you guy gather fri/sat nights??? I'm always out for a drive.
Last Sat night I was out and realised... not only was it 3am, but I was half-way to Lonnie (took a wrong turn) going via back roads.... :O
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2075354
Hey Dude, I sometimes go to the meets... (Kmart or with this ben at kamikaze)
I Think I saw you the other day when I was driving into work coming into town? Went flying past me (Silver R32) If it was, that is one tuff car!!
Might hook up with you this Fri Benny and bring a slab of meat? You going to be there??
You should stop by Greebo and we can meet and have a look at your ride :D
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2075430
You should stop by Greebo and we can meet and have a look at your ride :)
I'm afraid not mate... :) Pics below.. :)
New Toy
I might try and stop by, but I got the arvo off (to go driving) so I'm not sure where I'll be when :)
But at least I know, thx btw
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2077244
I think it was about monday / tuesday morning... coming down the brooker toward town (just approaching eski ice / foutain roundabout)
Not my normal route I usually turnoff at the domain (just after the hockey fields) cause, I free park up there, til I sort something out.
Anyway, no matter, we will meet sometime soon... :starwars:
https://www.sau.com.au/forums/topic/112532-new-guy/#findComment-2077918
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
