ok
NOS is partly o2 in a compressed form which enables more power from say a restrictive intercooler for the same area of oxygen, NOS has a much greater density of o2.
When you heat nitrous oxide to about 570 degrees F (~300 C), it splits into oxygen and nitrogen. When it vaporizes, nitrous oxide provides a significant cooling effect on the intake air. When you reduce the intake air temperature, you increase the air's density, and this provides even more oxygen inside the cylinder.
This overcums much of the flow restriction and heat related power loss. And since NOS is injected after the intercooler....the size of the intercooler has less effect on max power out put.
So as for being pointless and bearing no relevance, that is your veiw. Were I was pointing out that with the assistance of NOS a 10second time with ANY stock cooler would be more feasible.
  • Replies 46
Posted Images
guys i am not trying to find what is better than the stock cooler more the difference between a 600 dollar just jap cooler and a 2500 grand TRUST cooler that both are 600X300X100?
my advice is to talk to the guys at ARE here in Qld - a phone call is CHEAP :)
They may have done the tests you are looking for
They will be able to tell you why not all coolers are created equal
even if you don't buy one of their coolers - I've had a couple of 30 mins calls with them - they are VERY helpful
NO I do not own the company
NO I do not work there either :D
again - my 2c worth
Hi GTR 94,
I think the only way you will get the answer that you are rightly seeking is to do a LOT of research. Try speaking to the distributors ie Advan/ARE/JJ to see how they rate their coolers. Be prepared for a bit of frustration though because it's likely they either won't know or the way they measure wil be different. It's a constant source of amazement that aftermarket suppliers can't provide test results etc for a lot of their big ticket items but people keep buying their stuff so what can you expect? For example some time ago there was a thread on dump pipes - $1800 for CES ones and $1500 for Trust - and no one knows, including the suppliers, what their baseline worth is in terms of performance.
As itbmills wrote, a call to someone like ARE will probably arm you with a whole lot of knowledge regarding how FMIC are rated etc. and it might be best to call them before you speak to anyone else so they know you've done your homework.
Sorry that doesn't answer your question but I think it's the only path likely to yield the info you need. Hope to hear of some good results.
Cheers
Edited by Scooby
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
