if your looking for a good front stage i would recomended getting 6.5 inch splits.
as for brand go into your local car audio place and have a listen to a few diffrent ones and chose the one you like the best.
if you chose to get splits make sure you get an amp to utilise them.
mr 32
https://www.sau.com.au/forums/topic/112700-32-speakers/#findComment-2077581
yeah, definately go the 6.5" splits, just use some MDF and make a bracket for them and off you go...
as for brand, what mr 32 said, goto a car audio place and have a listen, make sure all the settings on the head unit you are testing off are set to flat, and the loud is off too, gives a better becuase you want the flat sound of the speaker to be the best sounding compared to othe ones, not the modified or bass boosted signal...
https://www.sau.com.au/forums/topic/112700-32-speakers/#findComment-2077619
as long as you make sure the magnets are going to clear the window when it's down, 6.5" splits are very nice in the front, fit i there pretty easy too... my mtx's have heaps of room between the window and the magnet, kenwoods are pretty thin too, not sure about pioneer...
https://www.sau.com.au/forums/topic/112700-32-speakers/#findComment-2079861
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
