hey not sure but hope this is only a clutch problem..
when driving...even 2nd 3rd gear, perhaps even first its hard to tell i dont stay in for long enough, i get the engine flaring a bit with out making the car go any faster.. this to me sounds like clutch slippage (yes im a noob to manuals).
Take up point isnt overly close to the top and it only at about 2500rpm + when the turbo spools. im wondering if i have to adjust something like the pedal travel thing but im not sure if that will give me more take up. This has all started in the last 200kms very quick and very slippy. Car is still driveable but no way of using the power i have. Car is R33 with stock turbo at 8psi full time.
any suggestions? im not really sure if its that the clutch is fully goone or if it needs something else i need some help
thanks guys
https://www.sau.com.au/forums/topic/112926-clutch-advice-please/
