i was out driving last night in the 33 (exhaust, pod, intercooler, 12psi) and an mx5 came up beside me, guy had the roof down and looked over at me. thought, ok, lets go. anyway this guy took off, got a good lead on me and i couldn't bring him back in.
i thought these things were slow fwd cars?? how did this one go so well
https://www.sau.com.au/forums/topic/113071-beaten-by-an-mx5-miata/
  • Replies 48
MX5's are rear wheel drive, all of them, do you mean MX6? They're FWD.
MX5 Turbo conversions very popular, so are 1UZ-FE V8 conversions.
The turbo convo expands their talents from an already highly entertaining sports car to also include being a missle.
Bugger all weight helps with these things :D
it had a badge on the back said 'SE'
MAZDA MX-5 SE
1839cc, four cylinders, in-line, belt driven DOHC, four valves per cylinder, variable valve timing, cast-iron block, aluminium alloy head, turbocharged.
124kW (ECE) @ 6000rpm
206Nm @ 4500rpm
1093kg
possibly the light weight is the factor. it being a convertable means less metal and glass weight. there is an almost 400-500kg difference between the cars. dont feel too hurt. find him again and go for a track race. odds are you'll beat him.
im willing to bet a lot of money the mx5 handles better than an r33
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
