Hi,
I've decided to sell my wheels, pending the arrival of new ones. The other wheels I ordered should arrive be tomorrow or Wednesday. The ones I am selling are 18 Inch work wheels with GTR offset, and sit very nicely on the car. The complete size is 18 x 8 with 20 offset. The car looks really fat from the back as it is a fairly wide tyre. The back two tyres are accetable in terms of tread. Front two will need replace at roughly $150 - $170 each if you can shop around. I think tempe has a cheap replacement tyre for somewhere in between that range if I remember correctly.
Check out the photos and give me a call. The wheels are in good condition, some have gutter rash - the usual (not battered though), but hardly noticeable in the pics and thats how it came. I think the price is very cheap for 18" work so please dont throw ridiculous offers my way. Anything under 650 id probably consider as ridiculous at this stage.
There are no center caps either. What you see is what you get :O
PM or give me a call on 0416 343 883.
Cheers
https://www.sau.com.au/forums/topic/113119-18-inch-work-wheels-for-sale-700/
Put me down for first dibs on them!
I'll call you tomorrow to give you an address and work out what freight would cost.
Cheers,
Ian Swinkels.
Hi Ian,
Sorry someone jumped in before you to have a look at them. I'll keep this post updated with the outcome, I should know by tonight whether they're sold or not
Cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
