Hey guys,
I used to have a R32 GTSt and swaped it for a SR 180sx, anyway the 180 spends 99% of its life in the shed and only gets driven on the weekend...if that!
Currently i have a daily R31 Silouette, and im looking at selling it and getting a R32 GTS 4 door, RB20DE i have one lined up and im going to look at it on the weekend!
Anyway my questions are:
1) What to look for when buying a 4 door, are there any "common" rust areas like the 2 doors (down the sides of the boot)
2) The 4 door im looking at is a Auto RB20DE and i was considering putting a manual box (and all appropriate things to go with it), whats exacilly is needed, do i need a manual ECU etc...obviouslly clutch cylinders and pedals, what about tail shaft length???
3) Do i need to run it on Premium unleaded? and what sort of km's should i expect from it out of a tank???
4) Also i have my old SR20DET brakes off of the 180sx (due to 5 stud conversion (S14 hubs n rotors, R32 GTSt front calipers), are these an upgrade for the R32 GTS's?
5) And how to i tell a GTS from a GTS type S???? my understanding is the typs s has hicas and turbo steering wheel.
6) what sized rims can i get under it, i have my old 180sx rims, they are 17" x 9's on the rear 8's front, sorry not sure on offset...but they fit on a S13! (the rear runs 235 width tyres streached over abit)
7) Sound...will the RB20DE sound cool with a turbo exhaust on it (3 inch) or will it be too drowny??? Or will it be over kill and loose power due too the exhaust being too big?
thanks very much
- Luke
PS...i just miss the RB note....damn it i want that sound back again!!!!
Edited by hawker05
ahh yes the sound of an rb, good to hear!
Haven't got time to answer your other qns, but always run it off premium it will drive/feel much better, you'll notice. i tryed mine on normal unleaded once and never again, it felt slugish to say the least.
i've got an apexi a1 exhaust system on mine, sounds great.....get something jap
3inch will definately make the car much more sluggish.. on my GTS i have a 2 1/4 cat back with JUN BL cannon, no mufflers in the line... straight through..I must say that i noticed a small decrease in low end torque believe it or not.and a very mild increase above 5000rpm. I get nothing but good comments about my exhaust note being sick nannas,best RB iv heard etc,etc..not that im bragging at all..
you will get slightly better fuel economy than a gts't driven mostly off boost.expect around 420-450km's o a tank around the city.. on the open road expect around the 600-650 mark if your not driving against the wind..
iv run my rb20de on normal pump fuel heaps of times... ran ok, untill my timing was advanced a few degrees then i found it pinged on very hot days...it does run best on premium.. iv found 95ron to be fine..
as far as the brakes you have, yeah they are definately an upgrade form stock GTS brakes.. GTS are single pot calipers... same size front discs though to the gts't.280mm. unless you have m spec brakes..
My understanding of how the models run isthat you can get a gts type s ( standard gts steering wheel,generally no hicas,blue background on instrument cluster,roundish front bar and no sideskirts etc) and a gts m-spec with pretty much all the same parts as the gts't just no turbo.
my wifes 4door gts't type s is practically identical to my 2door gts type s GTS..
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
