  • Replies 125
Posted Images
Hey Guys,
Very sorry for the amazingly long delays on the pics, but there are there now, well most of them, let me know if you want more and I'll organise them.
Cheers,
Dan.
I will definitely take the front bar and side skirts if still available, also do you have the front bar mounting behind it? I will take that too if so :) I will confirm by pm.
Also I will definitely take the wheels, and possibly with the tyres if I can scrape up enough cash soon enough. I don't suppose you'd be willing to part trade for 18x8.5's?
Hey Jim,
Front bar has a name on it, but I do have as of today the support for it available, make an offer I guess, don't even know what they are worth! :)
Skirts are still up in the air, somone has mentioned that they want them pending pics, I guess if not sold by friday they are yours!
Wheels are also a second in line thing... but I'll see again by friday.
Would much prefer to sell them with tyres, saves the dicking around.
Are you in the sydney area?
Cheers,
Dan.
Guys, all this stuff has to go, I'll consider and accept almost all offers, so lets get them going, grab yourself a bargin!
The car is back next Wednesday... and I need the space!
Cheers,
Dan.
Hi Dan, I take it the frontbar has either already been sold or you're holding it for the first guy in line...
If not then my cousin is still interested in buying it from you :laugh:
I haven't got the cash for it yet, but yeah, I'm holding it for a guy at the moment, if it falls through I'll pm you.
Cheers,
Dan.
PM's replied guys, thanks for asking for that stuff... I'll update to sold as soon as we exchange.
keep em coming gang... let get this stuff out of my garage and onto your cars!
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
