Hi all.
Just wondering if someone can point me in the right direction to find out on what the different number of flashes of the check engine light mean.
If it flashes quickly 3 times that means the knock levels above 60 and the engine is pinging right ?
Reason I ask is I saw it flash a few times awhile ago, and checked the hand controller on the PFC and the knock was only 12.
But I think this time it only flashed once or twice....not 3 times.
Usually when it flashes 3 times I check the PFC and the knock is above 60.
cheers
https://www.sau.com.au/forums/topic/113660-check-engine-light/
default settings:
injector duty exceed 98%
knock level exceed 60
airflow meter exceed 5000mv
the light will also come on and stay on for normal ecu/engine faults and if the boost kit is not connected properly and activated (it will stay on)
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
