I need some parts for my R32 GTR.
1. A full R32 GTR Drivers side Door Trim with Window and Mirrors electic controler (the whole inside of the door) Good Condition, no sun damage, no vynal pealing off and now marks on material.
2. 2x Back seat passanger roof mounted hand holders / Grips.
3. 1x Drivers side plastic floor protection cover saying " Skyline".
4. 2x Back side triangle window surrounds. Good conditon ones, no cracks or vynal pealing off or sun damage if possible.
5. A set of back seat orgianl R32 GTR Floor Mats with center mat.
(Only need Back floor mats)
Sorry I couldnt be clear on some items as I dont know what they are called.
I have included pics for more information
If you can help me get these parts please let me know :uh-huh:
email me at...
[email protected]
Pics here - Drivers Side door trim (Full)
https://www.sau.com.au/forums/topic/11381-r32-parts-wanted/
If you need pic of Back side triangle suround i can send it email or how ever to you, i cant post it, forums wont let me.
I also need a pair of Orginal GTR Sun Vizors
Please if you can help
M3M3NTO
https://www.sau.com.au/forums/topic/11381-r32-parts-wanted/#findComment-193759
  • 3 weeks later...
Hey Im still after these Items if someone can help.
1. A full R32 GTR Drivers side Door Trim (the whole inside of the door) Good Condition, no sun damage, no vynal pealing off and now marks on material. (Dont need electroic window/mirror controler)
2. R32 GTR Orginal Sunvizors, Same Material as GTR Roof
email me at
[email protected]
Thanks
https://www.sau.com.au/forums/topic/11381-r32-parts-wanted/#findComment-234080
  • 1 month later...
Im still after this Item
If anyone can help please pm or email me asap
Pic is above
https://www.sau.com.au/forums/topic/11381-r32-parts-wanted/#findComment-314015
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
