G'day guys,,
After buying a complete kit for my car, I have some other bits for sale,,
A complete GT Spec Genuine Hybrid intercooler kit (red pipes),,
retail for $1400.00 at Autobarn---brand new, boxed, with instructions and all parts,,never fitted
$800.00-- how about $600.00
^^^ Up for grabs again--- eBay sale fell through, buyer had his wallet stolen,,,
**how about $500.00,,, needs to go guys,,,**
******************************SOLD***********************************
Japmod SS321 High mount manifold,, (stronger than the chinese crap SS304)
paid $320.00-- brand new, boxed, never fitted
**************************************SOLD
XS power twin dump pipe
paid $129.00-- brand new, boxed, never fitted
$85.00********************************SOLD
Genuine Greddy type 'S' blow off valve , genuine boxed R32 / VG30 kit,
and also fits R33, this is a plumb back but 3 different sized trumpets can be purchased for it to adapt it to an atmospheric type,,
As new,,fitted up and driven twice for 1/2 hour each time,
Sounds awesome even plumbed,
as new with all fittings in original box,,paid $380.00
$280.00,, how about $240 ????*******************SOLD
will post pics tomorrow,, parts are in north Brissy
Cheers
John
Edited by 33GTT
https://www.sau.com.au/forums/topic/114283-new-r33-rb25-performance-bits/
Bit late on the pics guys, but here they are
post-23207-1146092297.jpgpost-23207-1146092520.jpgpost-23207-1146093216.jpg,,***SOLD****
post-23207-1146092378.jpgpost-23207-1146092464.jpg*************SOLD
post-23207-1146092578.jpg*******************************SOLD
post-23207-1146092705.jpgpost-23207-1146092759.jpgpost-23207-1146093094.jpg************SOLD
I also have an e-manage blue injector harness
$50
and the e-manage support tool, with cable,, new, unused and sealed,,,
$180
DUO33 --- PM replied to,,
cheers
John
Edited by 33GTT
Any Offers on the bits anyone?
I also have a S/H FMIC, (cooler only) with offset pipe outlets for plumbing back to original positions,,
GC,, $125.00
Edited by 33GTT
  • 3 weeks later...
  • 3 weeks later...
It was me Bryn, sorry dude, not for sale.
Thanks again John.
Chris
No problem Chris,,
Glad it went to someone who needs it,, my loss is your gain,,
cheers
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
