These rims are in good condition with very few marks. The rubber is in decent condition. It grips hard even in first. Rear are 9" wide with DUNLOP SP 9000 255/40
and front has continental 225/45 8"
I contacted JDM Imports and they said these rims are worth $1100
I will post $1000 and am a little negotiable
NEW PRICE $750
(ps the rim shown has the most marks on it - rest are clean as)
Edited by (",)
https://www.sau.com.au/forums/topic/114287-17-enkei-rims/
Oh my god! I had the cash for these two days ago! Had no idea something like this was for sale..
How hard would it be to get the 5 stud hub for my r33 gts to fit these on?
I am not sure of the offset with the non turbo ?? It fit perfect on the gts-t maybe you could get some spacers or something ?? Tempe seem to have a solution for fitting most wheels on different cars...
https://www.sau.com.au/forums/topic/114287-17-enkei-rims/#findComment-2113457
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
