i have a set of blue race seats to sell non reclinable they are daytons light as a mofo great condition with rails unversal wont take much at all to fix to a r33 ill have pics up later tonight these are comfy
asking $350 firm
plus postage can get freight cheap great condition
Edited by teazn_r33
https://www.sau.com.au/forums/topic/114331-race-seats-cheap/
asking $350 firm
what do they each weigh?
what's freight to perth?
what are they made from,how rigid structurally?
cheers
i had 1 of these in a previous car i was very shocked in how comfy they are i have broad shoulders n was tuff to find a seat that fitted well, i also checked and believe these are ADR approved!! make sure but i think theres a sticker on the bottom! unsure if rails are ADr approved tho
sorry pplz im in mildura vic but i can say that im a 6ft lad that weighs 100 kilos with a nice round gut "well paid for" and i fit in them with ease very surprising these are a good seat and ill have som more pics if you want tomorro
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
