Guest INASNT
Whats the easiest way to drop the db of an exhaust a few db, to under 90db coz i gotta go to bloody epa for a db and pollution control test next week?
I got a full 3inch system at the moment, with high flow cat and resonator. With a db tester from work its around 88db on idle when warm.I know they rev it to about 3000rpm for the test and i am sure it will be around 95 db at 3000rpm.
Whats the best way to quieten it down, and then ofcourse put it back to normal after the test? :D
https://www.sau.com.au/forums/topic/11455-drop-db-of-exhaust/
The test is done by an independant EPA chosen representitive. I believe that there is a listing on your piece of paper which lists who can do the test.
A silencer will only be accepted if the silencer is welded in place. A screw in silencer is not acceptable.
They reved my car to 5k and you must come in under 90db. I got 89db with a stock GTR exhuast on a totally stock R33 GTR.
Guest INASNT
dave
i gotta take my car to the epa place in mcloud coz the asshole cop tha canaried me reported to the epa i had my pollution control epuipement tampered with!! pfftt, so they do a db test, pollution control test and some other crap 2!
they shouldnt rev it to 5000rpm that bullshit.
"The A'PEXi ECV (Exhaust Control Valve) allows you to control the loudness of your exhaust sound. The ECV is installed right after the catalytic converter, and adjustment of the valve is done through a cable run from the ****pit to the valve body. All you have to do is slide the lever installed in the car to get the appropriate sound. With the A'PEXi ECV you'll no longer need to get out of the car to fit a detachable silencer into the tail pipe."
get one of them, i wanted one on my old vl being a 308, i thought yeah dump pipes. but then i thought nar its jsut a shitty vl.
Originally posted by INASNT
u reco if i got a fake rego sticker made up with my number plates but for a stock white r33 they would even realise?? coz all they have is my number plate and thats its a skyline.
not worth the risk...
maybe buy stock muffler and get muffler place like midas to put it on :D
that's a factory option on the 34's :D
sidewaysmambo is testing an aftermarket one out...
jsut to let u guys know, from experience.
RWC places take pictures of your cars if they have suspision that u will put your goodies back or/ removal of things.
then when u get tried for defects and u think o yeah im cool its all going to be sweet ill jsut show em my new rwc cert (QLD)
they will go and ring the rwc company up, the rwc company will most probably have pictures and u will be caught.
and they do ring and follow up trust me.
and be nice to cops too. their only doing their job. but some are assholes.
http://home.vicnet.net.au/~ozhog/Technical.../ozhogtech1.pdf
this link might help to show how the test is to be done properly.....
Breakdown....
Test to be done in open area.....
Mic's to be placed on a 45 degree angle facing the exhaust....
RPM:
1-5 cyl 4,000
6 cyl 3,200
8 cyl 3,300
Rotary, 4,500
It should equate to approx 100-110 KPH (maximum speed of vehicle by LAW)
(on road of course...:) )
No one else to be in the location during the test.....
But have a read through it's very interesting....
oh and INASNT what sort of exhaust do you have....
Loz
:burnout:
MotoX: its not as bad as QLD yet here in VIC, but it will soon get that way I guess. I haven't heard of anything like that happening. I think they _do_ however have a register here so if you keep getting busted you're in trouble.
Inasnt: I'd try putting back the stockie air box back on first before you go trying to change exhausts. That could make a difference to the overall noise level.
Is there anything (safe) you can stick in say, the dump pipe to deaden the noise for a little bit. Like stick in and then pull it out later?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
