Guest INASNT
Whats the easiest way to drop the db of an exhaust a few db, to under 90db coz i gotta go to bloody epa for a db and pollution control test next week?
I got a full 3inch system at the moment, with high flow cat and resonator. With a db tester from work its around 88db on idle when warm.I know they rev it to about 3000rpm for the test and i am sure it will be around 95 db at 3000rpm.
Whats the best way to quieten it down, and then ofcourse put it back to normal after the test? :D
https://www.sau.com.au/forums/topic/11455-drop-db-of-exhaust/
The test is done by an independant EPA chosen representitive. I believe that there is a listing on your piece of paper which lists who can do the test.
A silencer will only be accepted if the silencer is welded in place. A screw in silencer is not acceptable.
They reved my car to 5k and you must come in under 90db. I got 89db with a stock GTR exhuast on a totally stock R33 GTR.
Guest INASNT
dave
i gotta take my car to the epa place in mcloud coz the asshole cop tha canaried me reported to the epa i had my pollution control epuipement tampered with!! pfftt, so they do a db test, pollution control test and some other crap 2!
they shouldnt rev it to 5000rpm that bullshit.
"The A'PEXi ECV (Exhaust Control Valve) allows you to control the loudness of your exhaust sound. The ECV is installed right after the catalytic converter, and adjustment of the valve is done through a cable run from the ****pit to the valve body. All you have to do is slide the lever installed in the car to get the appropriate sound. With the A'PEXi ECV you'll no longer need to get out of the car to fit a detachable silencer into the tail pipe."
get one of them, i wanted one on my old vl being a 308, i thought yeah dump pipes. but then i thought nar its jsut a shitty vl.
Originally posted by INASNT
u reco if i got a fake rego sticker made up with my number plates but for a stock white r33 they would even realise?? coz all they have is my number plate and thats its a skyline.
not worth the risk...
maybe buy stock muffler and get muffler place like midas to put it on :D
that's a factory option on the 34's :D
sidewaysmambo is testing an aftermarket one out...
jsut to let u guys know, from experience.
RWC places take pictures of your cars if they have suspision that u will put your goodies back or/ removal of things.
then when u get tried for defects and u think o yeah im cool its all going to be sweet ill jsut show em my new rwc cert (QLD)
they will go and ring the rwc company up, the rwc company will most probably have pictures and u will be caught.
and they do ring and follow up trust me.
and be nice to cops too. their only doing their job. but some are assholes.
http://home.vicnet.net.au/~ozhog/Technical.../ozhogtech1.pdf
this link might help to show how the test is to be done properly.....
Breakdown....
Test to be done in open area.....
Mic's to be placed on a 45 degree angle facing the exhaust....
RPM:
1-5 cyl 4,000
6 cyl 3,200
8 cyl 3,300
Rotary, 4,500
It should equate to approx 100-110 KPH (maximum speed of vehicle by LAW)
(on road of course...:) )
No one else to be in the location during the test.....
But have a read through it's very interesting....
oh and INASNT what sort of exhaust do you have....
Loz
:burnout:
MotoX: its not as bad as QLD yet here in VIC, but it will soon get that way I guess. I haven't heard of anything like that happening. I think they _do_ however have a register here so if you keep getting busted you're in trouble.
Inasnt: I'd try putting back the stockie air box back on first before you go trying to change exhausts. That could make a difference to the overall noise level.
Is there anything (safe) you can stick in say, the dump pipe to deaden the noise for a little bit. Like stick in and then pull it out later?
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
