Beware I am a n00b when it comes to 32/33's, but as far as I can tell, yes the only difference is the lower mount's on the rear shocks ( please correct me if wrong )
That being said, whiteline do have a different part number between GTS-t and GTR. Seeing whiteline make a far superior product IMHO, probably higher spring rates to compensate for extra weight among other things like handling dynamics.....
Go for some whitelines, kings are way too soft :)
GTR's are around 200 kgs heavier that GTST's of the same model and most of that weight is on the front wheels. The same front spring rate makes no sense in that regard.
:) cheers :(
PS; check out the Group buy thread for Whiteline springs
http://www.skylinesaustralia.com/forums/in...showtopic=85467
Edited by Sydneykid
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
