hehe..THERE'S HEAPS MORE!! actually I've got a few with you in em :)
I scanned those two for something else, so i thought I'd pop em up here as well.
yeah a bit late...never mind ;):)
where's yours, SilverSlyder?? did you take any?
https://www.sau.com.au/forums/topic/1148-a-couple-of-pics/#findComment-23997
I think they might still be on my bro's memory card, I think. It's been a while now he might have deleted stuff of it, don't know?
I need to get a PC at home so as soon as i take any pic's i can post them up, but need the $$$$ first.
https://www.sau.com.au/forums/topic/1148-a-couple-of-pics/#findComment-24862
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
