  • Replies 91
Hi Brian,
I'm after the high pressure hose/pipe which is attached to the transfer case at the back of the gear box. This hose/pipe can be unscrewed easily. I've attached the pic of it; Please let me know if you have it.
Cheers,
Danny
Hi Brian,
Cheers,
Danny
Sorry mate, i do not have it, it was missing.
Edited by Midnight Racer
do u still have the indicators?? are they all orange or clear with orange indicator? where in southside of brisbane are u located? interested in door trims as well if they will fit a gtst.
sorry mate, indicators sold and pick up today. door trim is still avaulable. I live in stretton.
I think it can fit gtst bcz door size is same.
Do you have the two interior kick panels that is the cover over the computer on the passenger side and the other one is next to the drivers right foot. I'm also after the ash tray under the stereo and the two GT badges on the front guards. If you have these things please pm me your phone number and I will contact you. Thanks.
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
